  #11 (permalink)
Old 09-05-08, 07:50 AM
Ian Lloyd Ian Lloyd is offline
Just to add what I have done with my top steering column mount.
I had two plates welded either side of the Pilgrim Z bracket as mentioned above this really does stiffen things up.It stops the Z stretching or compressing. However, the chassis plate is fairly thin where is Z mount bolts, so as someone else suggested I used a piece of 3/16" thick plate about 12" long by 2" on top of the chassis. On a visit to Pilgrim I noticed they were adding this spreader plate to a fatory built car. This really makes the whole of the top column mount solid and I can give a really good heave on the steering wheel without the column moving up/down, left/right or forward /aft. It moved a lot before doing these mods.
Try these ideas and I am sure you will be happy with the result.
Do not bolt the collapsable section or as mentioned before you could become a human kebab, and the collapsable section in the steering column is an SVA requirement.
Happy building
Ian
Dax steering column MarkyC DAX Technical Questions 3 31-12-07 06:00 PM
steering column JonnyT DAX Technical Questions 4 14-08-07 06:02 PM
Steering Column lazyboy Viper Tech Forum 16 01-05-06 07:50 AM
Steering column drimman General Cobra Discussion 0 11-07-05 06:51 PM
Steering column for Gd Kelvin General Tech Tips & Questions 8 06-12-02 11:55 AM
