Old 07-05-08, 08:45 AM
bluetoon's Avatar
bluetoon bluetoon is offline
Sumo Caster
Hi Guys,
I need to make some adustments to the front suspension to improve self centering.
Does anyone know how to measure the castor angle?.
I would like to know what it is now then does some changes and see the effects.
Jim
How are the doors and bonnet supposed to fit again ? .
Old 07-05-08, 10:37 AM
chedz's Avatar
chedz chedz is offline
I measured mine as best I could but it wasn't exact.
To do it I jacked the car up level, then set plumb lines down from the centre of the hub, then using a vast array of clamps I attached straight edges to the hub in the same angle as the axis of the rotation (you end up with a triangle). Using a bit of pythagoras was able to work out the caster angle.
another interesting thing to do it draw a line across where the plumb line hits the garage floor perpendicular to the direction of travel, then turn the wheel and draw marks at regular intervals on the floor where the caster angle line hits the floor. You should then get an arc on the floor. As you approach full lock you can see the caster angle reduces until eventually the arc crosses the straight line and so you go from self centring to steering tightening. I suspect that the change in direction of the car as you move forward when driving would complicate this a bit and make it a bit better than it appears (more complex than I could calculate) but it shows how with insufficient caster you can end up running out of angle before full lock is achieved.
Hopefully this is clearish.
I still have a load of arcs drawn on my garage floor to remind me of happy times in the past....NOT!!!!
Graham
Old 07-05-08, 01:01 PM
bluetoon's Avatar
Hi Graham,
Thanks for that, I think i am getting a better idea now.
Can you have a look at the photo and check my understanding is right about where to get the lines from.
How much castor angle is about 'right' for the sumo. Or is it a case of "it self centres now" so that will do?
jim
Old 07-05-08, 02:36 PM
chedz's Avatar
Spot on.
I think its a case of more is better and don't think you can have too much really. There isn't a lot you can do other than move the top wishbone back by trimming the chassis tube down at the front so too much is unlikely. (or if like me you get really really desparate get some of Petes office furniture, cut it up and make new wishbones).
One thing to watch out for, make sure there is still slack on the bottom ball joints as the more you lean them over the closer you get to the stop at the back, I ended up putting washers at the front of the lower ball joint plate to angle them back slightly.
G
Old 07-05-08, 04:36 PM
sumoboy's Avatar
sumoboy sumoboy is offline
5 to 6 degrees is the aim
It's not what they tell you, its what they don't tell you !
50% of something, is better then 100% of nothing !
My Gallery: http://www.cobraclub.com/gallery/sho...page=12&sort=1
Old 07-05-08, 09:43 PM
gareth08's Avatar
gareth08 gareth08 is offline
Originally Posted by chedz View Post
Spot on.
G
Theres loads you can do just depends on how much time or money you have and how far you want to go
Gareth
Sumo Ford/T5 w/c and Nos
Old 08-05-08, 09:06 AM
chedz's Avatar
Ah yes, I forgot about that, you can always redesign the entire front suspension like Gareth has
My comments were refering to mortals like myself who only have an angle grinder and a bit of string available.
Old 08-05-08, 07:56 PM
Revets's Avatar
Revets Revets is offline
Hi,
An alternative way of measuring the caster that looks easier is described here - How to: Measuring Caster and Camber - How To - Circle Track Magazine.
They use a bubble gauge to measure the angle the wheel tilts, but with a plumb line and some trig you should be able to work it out OK.
Good luck,
Steve
Old 08-05-08, 08:21 PM
bluetoon's Avatar
Thanks Graham & Steve
Jim
caster angle,mk2 sumo. grizzly_a58 Pilgrim Sumo Technical Questions 5 15-08-07 09:11 PM
Caster & Camber tool for YOU Cobra289 General Tech Tips & Questions 1 17-06-05 10:29 PM
Sumo front caster William Pilgrim Sumo Technical Questions 5 17-06-05 04:08 AM
More than 3 Caster shims, is that OK? Cobra289 General Tech Tips & Questions 22 17-05-05 08:39 PM
Caster & Camber Setting. mikey General Tech Tips & Questions 10 18-02-02 12:44 PM
