Old 07-05-08, 10:16 PM
jonny m's Avatar
jonny m jonny m is offline
Tyre Pressures
Need to get the suspension set up better than it is currently, now running 16" rims with adjustable shocks set about halfway on the clicks.
Going over big bumpos causes me to bounce out of my seat and car becomes hard to control.
Will tyre pressure setting make a difference - anyone found out what works best for 16" ?
Jon
Don't take life too seriously...no one gets out alive in the end.
Old 07-05-08, 10:56 PM
stevee8's Avatar
stevee8 stevee8 is offline
20 - 22 psi won't be far out all round.
Steve
Old 07-05-08, 11:56 PM
CycleSi CycleSi is offline
l'm running 22 front and 20 rear on 215/55 x 16 and 245/55 x 16 with 48/52 weight distribution.
Old 08-05-08, 04:47 PM
jonny m's Avatar
Cheers, I think i am a bit higher at the moment (24 ish) will dropping down reduce the amount of bounce, of should I click up the shockers adjustments too ?
Jon
Old 10-05-08, 07:50 PM
stevee8's Avatar
Suggest you try reducing the tyre pressures first as they are easier to get at & see what difference that makes.
If you still feel the ride is too hard you can then tweak the valves on the shocks.
Steve
Old 12-05-08, 02:02 PM
jeff's Avatar
jeff jeff is offline
Had same problem when first on the road, thought that I had set it up all to stiff but in fact the spax shockers were set to the softest setting and hardley worked. Wound them in all the way and come back 6 clicks and sooo much better
Jeff
My next one is going to be AK
Old 23-05-08, 01:28 PM
jonny m's Avatar
My shocks no longer click on adjustment (after a mere 1.5k miles!) so just turned one revolution clockwise, and set pressure at 22psi all round and seems a bit better, thanks folks
Tyre Pressures viperman General Tech Tips & Questions 5 06-04-08 09:04 AM
Tyre pressures CycleSi General Cobra Discussion 8 11-01-06 10:07 PM
Tyre pressures bazbo Engine Tech Tips & Questions 2 20-12-04 11:20 AM
Tyre pressures Daxter General Tech Tips & Questions 5 09-10-04 05:23 AM
tyre pressures! fcukruss AK Technical Questions 3 12-04-04 05:53 PM
