Old 13-05-08, 06:42 PM
chris98m chris98m is offline
Rv8 Alternator
Hi I have a rv8 3.5 sdi engine with standard alternator bracket I am useing a p6 water pump any ideas on which small alternator will line up chris
Old 14-05-08, 08:11 AM
pelham939 pelham939 is offline
hope this helps
i've just bought a new second hand Sierra alternator for my RV8 i use it in connection with the Pilgrim alternator mount - it lines up OK - when i bought it i did point out that there was a potential handing problem with these alternators the guy said no problem loosen the 3 nuts that hold the unit together partially separate the alternator and rotate the rear to line up with other front mounting - worked a treat cost £15 and charges like a good un - not like the first one i bought which had i known would have been easy to sort out rather than bin it
HTH
Ian
Alternator maverick General Cobra Discussion 9 14-06-05 05:46 AM
New alternator Timsafc General Cobra Discussion 5 19-04-05 09:10 PM
Alternator Novacatt Pilgrim Sumo Technical Questions 2 29-01-05 05:23 PM
Alternator? Shaney23 General Tech Tips & Questions 4 27-10-04 02:22 PM
My Alternator Goldie General Cobra Discussion 0 11-10-04 10:21 PM
