Old 06-06-08, 06:59 AM
Gromit's Avatar
Question front suspension
hi all
has an one made there own front suspension arms for the pilgrim kit in order to get there caster/camber right & did you make top/bottom arms adjusterble !
gromit
Old 06-06-08, 07:09 AM
kevchard's Avatar
Hi Gromit
What running gear was it you had? Was it Cortina, if so i would be interested aswell.
Nice to hear you are progressing .
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 06-06-08, 10:37 AM
KevinW's Avatar
see Gareth08 for the best solution.
CAP 326Y finally road legal. Pilgrim Mk III RV8.
Old 06-06-08, 10:47 AM
v8steve007's Avatar
Also pete (sidecarbod) as he seems to know them insideout
Old 06-06-08, 10:52 AM
Tony M has really sorted out his suspension now and knows most if not all the fixes. He normally comes along to the East Midlands meet if you want to have a chat to him.
Although he does use quite a lot of ballast in his which might help
Old 06-06-08, 06:53 PM
Gromit's Avatar
Thumbs up suspension
Originally Posted by kevchard View Post
Hi Gromit
Kevin
it is cortina, took it to av it 4 wheel aline & it was all over the place n/s/f is well in at the bottom. so think im going to make top & bottom arms fully adjusterble.
Old 06-06-08, 07:00 PM
Sidecarbod's Avatar
Cheers for the vote of confidence but I only know about the MKIII jobbies!
Pete
Old 06-06-08, 07:13 PM
stu e's Avatar
I have a MK2 and had front tyre wear problems. I took it for an MOT and the tester thought it was the camber, i took it for an alignment check and all was within Pilgrims spec, it turned out to be a combination of tracking and bad tyres.
The guys on here suggested a top adjustable wishbone, as I believe it is under less load than the lower. I was thinking of trying a MK3 upper wishbone as it's adjustable, and got some dimensions from Gareth(i think). The dimensions should be in an old post. I no longer has access to workshop but i believe a set of wishbones could be made.
HTH Stu.
Old 07-06-08, 07:14 AM
Gromit's Avatar
Smile suspension
they stu - e, with two rose joints for the inner & a track rod end for the outer, could do with some measurments before i av ago.
Old 07-06-08, 02:45 PM
stu e's Avatar
The measurements Gareth gave me for a MK3 upper wishbone were 168mm between the inside of the bushes and around 255mm between the centre of the bushes and the centre of the top ball joint. I seem to remember the 255mm was greater than I measured a Cortina wishbone.
I would think with the right facilities something could be made.
HTH Stu.
Front suspension -How Stiff? Simon R General Tech Tips & Questions 2 27-03-07 11:39 PM
Jag Front Suspension midlifecrisis General Tech Tips & Questions 3 05-04-05 09:24 PM
Jag front suspension? garyholden General Cobra Discussion 7 19-08-04 12:18 PM
sumo 2 front suspension mickcorn Pilgrim Sumo Technical Questions 1 01-06-04 11:59 AM
Front suspension Miket General Tech Tips & Questions 6 26-01-02 09:11 PM
