Old 16-06-08, 10:53 PM
Gazzab's Avatar
Rear Red Brake/Side lamps
just refitting the rear side/brake lamps to the rear now paint is completed and noticed that there are no markings on the lenses, the indicators are marked with the correct markings and are the same type so i was wondering if i will get through the sva ok or must all lens bear the relevant markings.
Gary
Old 16-06-08, 11:40 PM
Clive's Avatar
Hi Garry,
As far as I'm aware the rear lights do not need to be "E" marked, as long as they meet the radius requirements, position, and are bright enough they should be acceptable.
Cheers, Clive
Old 26-06-08, 08:15 AM
My rear indicators lights are E marked but ot eh rear side brake light and they passed the SVA.
I mounted the indicators at the top with the E mark facing up so it was easy to see.
It worked for me
Ian
Old 26-06-08, 09:02 AM
lutman's Avatar
Gary
According to SVA 9.1 Annex.1 there should be an " 'E', 'e' , Identity symbol or BS mark "
on each lens. Only if they are a combined cluster is it ok to have a single E mark or equivalent. It is then up to the applicant to prove, if requested, that the equivalent mark complies with UK standards.
Having just reread the section in the SVA manual detailing reasons for failure I noted that nowhere does it state that not having an E mark or equivalent is a cause to fail ?
It only states, quote - " except in the case of a headlamp,not of a similar brightness when compared with a lamp bearing an appropriate approval mark as given in annex 1" end quote.
So I read that as long as the lamp brightness can be compared to a similar E marked lamp the actual lamp doesn't need an E mark ????
Can any one enlighten (pardon the pun) us.
Chris Lutman - Daytona Coupe
Old 26-06-08, 09:33 AM
Clive's Avatar
SVA Notes, Section 9.1 Note 3 states:-
"The brightness of lamps bearing an appropriate approval mark, as given in Annex 1, defines the acceptable standard. Lamps not bearing such a mark should emit light of similar brightness."
From this I gather that as long as the lamp is as bright as one with the approved mark, it is acceptable.
The approval mark E or e Identity symbol or BS marks are:-
Rear position lamp - "R"
Stop Lamp - "S1" or "S2"
Cheers, Clive
Old 26-06-08, 09:40 AM
You don't need an "E" mark as long as they are the right colour, intensity and radius. I fitted the 488 style ones, which don’t have an “E” mark on them and they passed OK, and in November last year a friend of mine had the same result at a different centre.
Jag rear brake upgrade richardd General Tech Tips & Questions 5 13-04-08 11:23 PM
Bolts needed & warning lamps Spanish Dave General Cobra Discussion 6 28-10-07 10:56 PM
Brighter rear lamps nbracken General Tech Tips & Questions 17 30-10-05 08:35 AM
Rear Fog Lamps & GB Badges V8 BJC General Cobra Discussion 2 13-11-04 04:49 PM
rear near side wheel spacing perky Pilgrim Sumo Technical Questions 3 25-04-04 05:49 AM
