  #11 (permalink)
Old 24-06-08, 05:13 PM
Originally Posted by Stu J View Post
From the front of my chassis the first wishbone bracket on the (good) o/s is 100mm, compared to 115mm on the n/s.
The suspension upright on the o/s is 40mm away from the rear wishbone bracket, compared to 45mm away on the n/s.
The cross member between the front chassis which has the steering rack mounted its different either side so that geometry can't be right.
Assuming however the chassis IS supposed to be like that why would you need to achieve different calculations in order to get the steering and suspension set when the welds are clearly different?
Hi Stu
I can understand your concern, it seems that if all the measurements are different, then there is no apparrent datum point from which to determine any alterations/allowances to be made.
I wish I was qualified to help, perhaps the critical dimension should be on a technical drawing that Pilgrim should be able to provide... presumably at some stage in the design procccess, these ponts would have been determined (with calculations etc)... or at least the Jig dimensions.
I think we have all done some modifications to the steering, and it seems like we rely on the experience of others to go by, rather than adhere to an exact set of geometric criteria & dimensions, as should be supplied by the manufacturer.
Keep us posted anyway
good luck
Rowly
  #12 (permalink)
Old 24-06-08, 05:43 PM
Stu J's Avatar
Hi Rowly, as you suggested it is all probably in their calculations but find it funny how either side are different measurements from wishbone to uprights , perhaps I have a rogue chassis, that is the only constructive solution I can think of.
Anyone from pilgrim reading ?????
C an
O nly
B e
R eal
A drenalin
  #13 (permalink)
Old 24-06-08, 08:46 PM
jeff's Avatar
set of tech drawings from pilgrim, am I the only one LMAO
Jeff
My next one is going to be AK
  #14 (permalink)
Old 02-07-08, 12:40 PM
KevinW's Avatar
duplicate post deleted.
CAP 326Y finally road legal. Pilgrim Mk III RV8.
  #15 (permalink)
KevinW's Avatar
Asymmetry
- everything is asymmetric on these cars, as were the originals. we can argue about how much asymmetry is tolerable, but they are ALL like it, sumoes and non-sumoes (except maybe the kirkham).
  #16 (permalink)
Old 02-07-08, 03:13 PM
Assymetry
I take your point Kevin, about all models not being precise, but it would have been nice to have a set of geometrical, symetrical datum points from which to work, in order to obtain acceptable results. Perhaps from the original drawings, or even notes from the original guesswork would have helped!!!!
Symetry is an interesting subject though!
In Nature, An apparrently symetrical snowflake, at a molecular level would look like a jumble sale. Even the human body, roughly symetrical (left to right), but organs like the heart & liver are offset...... and actually....all adult males have the left testicle hanging lower than the right one!!!
(maybe I should have specified this when I was ordering my Sumo seats!)
No.. really, this is true!, generally if this is not the case, then some organ "reversal" has occurred, which if severe (arterial plumbing etc), can result in a newborn not surviving.
(I think i'll stick to trying to put kits cars together)
Rowly
Which wishbone? grahamf General Cobra Discussion 5 21-06-05 09:04 PM
Cut off lug on wishbone Kelvincob General Tech Tips & Questions 3 08-01-04 01:13 PM
Inner wishbone mount?????? STEVE G General Tech Tips & Questions 4 29-10-03 09:39 AM
Upper wishbone magna_swede General Tech Tips & Questions 15 07-02-03 06:49 AM
Upper Wishbone mikey General Tech Tips & Questions 1 17-02-02 09:40 PM
