Old 25-06-08, 08:10 PM
Single Roll Hoops
Hi,
I a thinking of fabricatig 2 x single roll hoops for my Sumo build. Could anyone please tell me what the dimension is between the inside of the 2 legs?
Any help much appreciated.
Thanks,
Andy
Old 26-06-08, 12:47 PM
philip600's Avatar
Single Roll Hoops
Hi Andy,
Not sure what you mean by ''measurement between inside of two legs'' but centre to centre mine are the following -
Single hoop = 275mm
outside legs = 950mm apart
inside legs = 400mm apart
As I said these are centre to centre measurements, if you measure from between each leg this will vary depending on the diameter of tubing you use.
Hope this makes sense & is of some help.
Regards Phil.
Four2Seven
Old 26-06-08, 03:09 PM
Originally Posted by Kimpy21 View Post
Hi,
Thanks,
Andy
Surely the bosses will already be welded to the chassis which will determine the distance between centres of the roll bars, or are you going to fit the mountings as well.
Old 26-06-08, 05:10 PM
Thanks for response Phil, I guess another way of putting it would be the inside diameter of the 180 degree bend at the top of the hoop.
Andy
Old 26-06-08, 05:12 PM
Thanks for the response TINKA, the Sumo chassis only comes with the outer bosses welded in order to fit one double sized hoop across the full width. If you want 2 x single hoops you have to fabricate the inner bosses and position them yourself.
Andy
Old 26-06-08, 06:30 PM
philip600's Avatar
Hi Andy,
As I said it will depend on diameter of your tube but mine are 275mm centres & 225mm between the tubes which are 50mm diameter. ( 275 - 50 = 225mm ) As you've said you will have to fabricate the inside mountings so I would get the hoops made first & position mounts to suit !
Regards Phil.
Four2Seven
Old 27-06-08, 11:17 AM
Cheers Phil. I have found a tube bender local (Sheffield) that can bend the pipes to 226mm inside diameter which will mean the legs are 226mm apart, 276mm centre to centre. Thanks for your help.
Andy
roll hoops john w General Cobra Discussion 14 03-05-08 09:18 PM
Three leg roll hoops Phil Peatfield Pilgrim Sumo Technical Questions 2 14-09-07 10:16 PM
Roll Hoops TonyD AK Technical Questions 0 29-05-07 08:14 PM
Roll over hoops stabber General Tech Tips & Questions 5 26-01-07 10:09 PM
Roll Hoops Phil McCann Pilgrim Sumo Technical Questions 5 31-10-04 08:20 AM
