Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Dunc is offline Tyre Kicker
    Join Date
    Oct 2010
    Location
    Haconby, Lincs
    Posts
    12
    Rover V8 low idle/rough running
    Took my Sumo for what was supposed to be a 20 minute blast yesterday and ended up with a problem! She started fine and I then took it easy for 5 minutes to let her warm up. Pulled into a drive to turn around and reversed out on full left hand down lock and heard a small clunk. From then the car backfired and ran rough until I got to a junction where I noticed the idle speed was down at 500rpm, normally it's 800. Then she stopped. And wouldn't start. Luckily it was outside a pub and the landlord was very accommodating! Eventually got her to start on jumps and she spluttered her way home, not happy. Today I popped her up on jacks and looked at whether going full lock LHD snagged anything. I checked all the leads onto the plugs and then fired her up and she started fine. She then idled fine for 10 minutes and so I stopped her, got her off the jacks and started her again. This time she started rough and had the same idle problem as yesterday with backfiring when I increased the revs. So I put her back in the garage.
    Any ideas?
  2. #2
    Sidecarbod's Avatar
    Sidecarbod is offline Driving God
    Join Date
    Mar 2006
    Location
    Location Location is a crap TV program
    Posts
    7,105
    More info required!
    What fuel system are you running? EFI, carbs? (what carb/s)
    What ignition system has it got fitted?
    Rules for buying 'Go Faster' parts:-
    If it's fast and cheap then it's not good.
    If it's cheap and good then it's not fast.
    If it's good and fast then it's not cheap!
  3. #3
    Join Date
    Oct 2010
    Location
    Haconby, Lincs
    Posts
    12
    Sorry! Its an Offenhauser manifold with a 4 barrel holly carb. That, I'm afraid, is as much as I know at the moment. It's got optronic electronic ignition from S & S preparations I think.
  4. #4
    Sidecarbod's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    7,105
    Quote Originally Posted by Dunc View Post
    I'm afraid that I know nowt about Holley carbs! The problem could be due to carb icing. Do you have an insulator between the carb and the manifold?
    Your ignition could be at fault but since it is not an Opus jobbie I doubt it.
  5. #5
    robcob's Avatar
    robcob is offline Chief Engineer
    Join Date
    Dec 2007
    Location
    cheshire
    Posts
    1,310
    Any ideas?
    Start with the basic checks,
    is it getting fuel and is the pump working ok
    are the plugs all sparking
    plug leads all working
    check timing
    could be the power valve in the carb
    rob
  6. #6
    slogger's Avatar
    slogger is offline Driving God
    Join Date
    Feb 2006
    Location
    Somewhere in Kent, I think?
    Age
    51
    Posts
    5,562
    Just a thought for what it's worth:
    If it appears to start and idle ok jacked up but shows this fault when on the ground, could the float level be suspect? Does the thing smell of fuel when it is running rough/black or grey smoke from the exhausts?
    Don't know what the connection to the clonk could be unless something mechanical is to blame.
    Just a thought as I said. Crystal ball fault diagnosis is always a bit suspect.
    Ian DAX 454 Chevy
    It's not shabby!............. Just has a highly developed patina! My Gallery Take a look.
  7. #7
    Join Date
    Oct 2010
    Location
    Haconby, Lincs
    Posts
    12
    Amendment
    Thanks for the advice fellas. I re checked the carb on and its a webber 500 not a holly.... Getting to know the car slowly but surely. Anyone think this makes any difference?
  8. #8
    Join Date
    Oct 2010
    Location
    Haconby, Lincs
    Posts
    12
    It does smell strongly of fuel, so I'll look at the carb. Could be carb icing too. Thanks again for the thoughts.
  9. #9
    Sidecarbod's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    7,105
    I know a bit about the Webber 500.
    If you are sure that its going rich when the idle goes rough then its very likely just crap in the float valves. The weber is easy to work on, you can remove the top of the carb in about 5 minutes, the floats will come off with it.
    It would be worth posting up what fuel pump you have and whether you are running a fuel regulator. The Webber will not tolerate more than 6.5 - 7 PSI pressure. (Mind you if the pump pressure was too high it would flood all of the time)
    When you remove the top of the carb make a note of the hole that the accelerator link was in and remove the air filter stud to prevent ripping of the gasket. If you are careful you can re-use the gasket many times.
  10. #10
    Sidecarbod's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    7,105
    Carb icing will make it run rough but not rich, just rough! I bet its just crap in the carb!
  1. Rough idle and black smoke when warmed up
    By swinfen in forum Engine Tech Tips & Questions
    Last Post: 20-09-10, 11:38 PM
  2. Slightly rough running.
    By craggle in forum Engine Tech Tips & Questions
    Last Post: 05-05-08, 06:25 PM
  3. Rough Idle
    By Glyn_Turner in forum General Tech Tips & Questions
    Last Post: 21-09-05, 12:06 PM
  4. Rough Running
    By cheepskate in forum Pilgrim Sumo Technical Questions
    Last Post: 18-04-04, 12:27 PM
  5. Rough Running Chevy 350
    By Andy427 in forum General Tech Tips & Questions
    Last Post: 17-09-01, 09:22 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
