Old 01-12-02, 04:53 PM
Question for RV8 Sumo Owners
How close is your offside exhaust manifold to the steering column, at the uj?
I've just trial fitted mine and it seems altogether too close - maybe 1/4 - 3/8 inch. Far enough to turn, but maybe near enough to touch if the engine shakes...
thanks chaps
b
Old 01-12-02, 06:55 PM
RE: Question for RV8 Sumo Owners
What sort of exhaust manifolds are you using? I have the Pilgrim supplied ones and there is pleny of room.
Tony B
Retired for now......
Old 01-12-02, 09:24 PM
I have the Pilgrim ones, too.
How much space do you have at the front of the engine? I wonder if I have to shift forward a bit, though there isn't that much space...
Old 02-12-02, 10:37 AM
Bernie,
What chassis are you using, and what steering column?
Most of us have the MkIII Sierra-base chassis, and therefore use the sierra steering column.
Are you using sidepipes or underslungs, again most of us use sidepipes, and theres plenty of room, as Tony said previously.
If none of this helps, suggest you post a pic so we can see the problem.
Kevin
Old 02-12-02, 10:42 AM
My Pilgrim manifolds come close enough to the steering joint that the exhaust wrap on the manifold has been cut by the joint. It does not actually seem to touch metal-to-metal but it is close !
Old 02-12-02, 05:14 PM
Paul's is the same as mine, then - I have the Sierra MKIII chassis, with all the standard bits and side pipes - if I wrap the manifold the wrapping will jam the steering.
I've been looking at the engine after work today, and I think if I lift it a bit, it may move forward a touch to make things a bit better, but I won't manage "plenty of room" like Tony. And I can't move it very far forward, because then I won't ever be able to get the fan belt off.
BTW - different subject - I bought the 1100mm fan belt as in the book, but it was too long, 1075 was better, for those following along behind!
Old 02-12-02, 07:10 PM
And here are some pics -
The manifold - is it the same as everyone else's?
The engine front end gap, about two fan belts
Old 03-12-02, 08:55 AM
Sidepipe mainfold looks the same as mine.
My gap at the front is about 1 fan belt's width.
If I can get a weekend pass to look in the garage I'll see what the gap looks like on the steering column.
Kevin
Old 04-12-02, 10:03 AM
Dan Dan is offline
Bernie,
I also have 'plenty of room' between the steering UJ's and the exhaust manifold (Which is also wrapped). Your photo's of the front clearance shows that your engine is alot further back than mine though. I am just able to fit a fan belt through the gap at the front (It needs to be squished a little)
Old 04-12-02, 08:42 PM
Well, thank you, team. I looks like I'll have to get my scaffolding A-frames and hoist out again, and shift the engine forward a bit.
Ho-hum
thanks again
Pilgrim Sumo Owners mr bidd General Cobra Discussion 11 17-10-06 12:23 PM
Sumo alternator question darren General Cobra Discussion 4 16-02-06 08:04 AM
Question for GD owners Andy302 General Cobra Discussion 2 06-09-03 01:06 AM
Granada Based Sumo Owners - Beware !!!!! Mike H The Cockpit 1 31-03-03 05:58 PM
question for sierra-based Sumo owners re taper drill interestedparty General Tech Tips & Questions 7 17-11-02 05:08 PM
