Old 14-04-03, 03:31 PM
tonym's Avatar
Club Chairman
engine removal
has anyone took a rover v8 out of their sumo after the body was fitted? was it a generally easy job or a bit of a b**ch
thanks
tony
BIG TONE
Old 15-04-03, 03:02 PM
Dan Dan is offline
RE: engine removal
Yes it can be done. You will need a crane with a high lift. The area to watch out for it the front where the bonnet hinges are (The bonnet will need to come off) The engine it'self will come out fairly easily - the gearbox will hang lower and needs to carefully guided out. To avoid this you could always split the engine/gearbox in situ and lift out each individually...
Old 15-04-03, 03:44 PM
RE: engine removal
Personally I would split the engine and gearbox first, taking only the engine out. Getting the box off the engine is simple enough when the car is up on axle stands - believe me, I've done it often enough.
As for taking out the engine, well I had mine stripped to the bare block in December last year and it probably wouldn't need a crane to remove just that. Couple of strong blokes to lift should easlily do it.
Tony B
Retired for now......
Old 15-04-03, 06:39 PM
tonym's Avatar
Club Chairman
RE: engine removal
thanks guys, i can now put a used engine in mr sumo to get it on the road before the end of summer and rebuild an old block to the spec i want over winter and put that in next spring
thanks
Tony
BIG TONE
T56 Removal jamesLS7 Gardner Douglas Technical Questions 5 17-10-07 05:22 PM
Gearbox removal rileyhr DAX Technical Questions 6 18-07-07 07:52 PM
removal of advert tonym Feedback, Membership and Help 1 24-04-05 07:17 PM
Flashline Removal steve.hills Pilgrim Sumo Technical Questions 2 04-01-05 04:15 PM
Seized Rover Clutch / GD Engine Removal Happy Jim General Tech Tips & Questions 12 03-05-02 04:34 PM
