| steering / front end feels 'wrong' after spin-off - adv... Hi all, having a few probs with the front end. I have a Mk 2 sumo with ford sierra running gear. I recently had a little incident with aquaplaining and bumped into a curb. It was at low speed, but now the steering is 'all to cock' for want of a better expression. the steering wheel is now about 20 degrees rotated permanently, the wheel does not centre itself if you let go whilst turning, and there is a lot of play in the steering, especially under power when the front end is unweighted. I know next to nothing about suspension geometry / tracking setup. Can someone please tell me what I might have done? any advice would as always, be greatly appreciated Nick B |
| RE: steering / front end feels 'wrong' after spin-off - adv. Hi Nick, Your not having much luck. Both steering and clutch problems in the same week. x( If it was only a slow speed run up the curb then you are unlikely to have bent wishbones or mounting positions - but it's worth just quickly checking for any bent bolts. Likely case is that you've shagged the tracking, Any compotent MOT garage can sort this, I use P J Autos (Just on the left as you go under the By fleet and new haw bridge). Tel : (01932) 348 093 and ask to speak to Paul. The steering wheel can be realigned to center by removing it and refitting after the tracking has been sorted. Dan ~ http://homepage.ntlworld.com/danny.mann/ http://images.animfactory.com/animat...ood_md_wht.gif |
| RE: steering / front end feels 'wrong' after spin-off - adv. Cheers Dan, its booked in for next saturday, should give me time to get my new sidepipes on and replace that clutch cable. Nick B |
| RE: steering / front end feels 'wrong' after spin-off -... thanks Paul, thats an incredible deduction, do you work in diagnostics?:P :P :P |
| RE: steering / front end feels 'wrong' after spin-off -... I guess paul must be a consultant ? did he charge you for the info {-} |
| RE: steering / front end feels 'wrong' after spin-off -... Have a look at the track rod arm as you will probably find it is bent |
| A quick spin | Stu J | General Cobra Discussion | 4 | 09-12-07 06:50 PM |
| Sumo Mk2 front steering/suspension | slider | Pilgrim Sumo Technical Questions | 4 | 04-12-06 01:29 PM |
| Feels good today... | Goldie | General Cobra Discussion | 4 | 24-08-04 09:41 PM |
| Wrong fuel tank or wrong brackets? | craggle | DAX Technical Questions | 4 | 15-08-04 07:43 PM |
| Front Suspension, Steering wheel and Loom | brianp | Pilgrim Sumo Technical Questions | 5 | 25-02-03 09:11 PM |
