| Door Locks Can anyone advice on what do do to fit the door latch/lock and strike plates on the Pilgrim. I am lothed to start drilling holes etc. until I know a bit more about what to do. Many thanks for your help |
| RE: Door Locks Do not trust the outline on the Sumo door as it is too large! If you start by cutting a small groove where the outline has been made, this will give you a good idea of where the lock will be fitted. Make up a cardboard template the same size as the door lock and mark through where the screws should be fitted. You can then place this up against the door and mark where the holes can be drilled. Once done, you will be able to fix the lock in place and then see how much the groove you cut out earlier needs to be enlarged. Take it slowly and you'll get a good finish. Good luck. Tony B --- http://homepage.ntlworld.com/tony.breski |
| RE: Door Locks Frosty When I did mine i cut the lock section out of the sierra door and used that as a template as mentioned in the first reply. As Tony suggested, it is worth taking a bit of time on to get it right. Mark |
| Door locks | ceejayjay | Ram Forum | 3 | 15-11-07 03:11 PM |
| Door Locks | JonnyT | DAX Technical Questions | 3 | 01-07-07 02:20 PM |
| AK door locks | mike tabram | AK Technical Questions | 6 | 04-04-06 09:47 PM |
| which door locks ?? | MARTIN123 | General Tech Tips & Questions | 18 | 30-09-03 12:36 PM |
| Door Locks | Bigblock | General Cobra Discussion | 3 | 23-06-03 01:46 PM |
