| Fuel gauge sender fitting Just looking at my set of Gauges and senders from Pilgrim (ETB), the fuel sender has six holes whilst the tank only has 5 fixing holes , is this the norm? My initial thought is to leave the tank undisturbed and re-drill the sender flange and make a new gasket. Then use self tappers to fit. Where could I purchase the correct type of rubber for the new gasket? Steve :} |
| RE: Fuel gauge sender fitting Yup, another Pilgrim special ! The Fuel sender unit is the correct one, but you need to adapt the Tank. I was advised by Tony to drill the tank and then fit. Just make sure you catch any swarf so the tank stays clean. Regards Dave ' and it was going oh so well ' |
| RE: Fuel gauge sender fitting I drilled the tank useing rags and a magnet to catch the swarf. If you insert the bolts "sticking up" these can be secured with a turn of wire on each one. loose fit the gasket, sender, washers and nuts, remove the wire and tighten. Dave. |
| RE: Fuel gauge sender fitting Dave, Cheers, worked a treat, only dropped one into the tank !, long rod with sticky tape on the end got it out again.. :} Steve :tu |
| Fuel tank sender/fuel gauge | Dek | General Cobra Discussion | 3 | 16-05-07 09:34 AM |
| Fuel gauge sender gremlin. | DavidSaw | DAX Technical Questions | 4 | 03-01-05 12:34 PM |
| Fuel Sender Fitting | Trevor | General Tech Tips & Questions | 10 | 22-09-04 09:05 PM |
| Water temp. gauge/sender question | ian | General Tech Tips & Questions | 6 | 31-07-03 09:21 PM |
| Fuel Gauge Sender Unit | VinceGledhill | AK Technical Questions | 1 | 12-03-03 12:41 PM |
