Old 29-07-03, 10:07 PM
heater
What have people done about the heater control?
I've been working away at my better-than-Pilgrim dashboard design, but I'm having writers block with the stupid non-SVA lever thing. Perhaps I shouldn't bother, and just leave it on "screen", or maybe inset it, though the little panel on the Mini heater is so tacky...any artistic, stylish, yet simple suggestions?
Old 30-07-03, 12:04 PM
RE: heater
Took mine off and left it directed at the screen. Then engine bay does get quite warm from the heat of a V8 engine. If this is not enough then you can always insert a Y-shaped piece of pipe from the screen and direct this to the cab for additional heat.
Tony B
Retired for now......
Old 30-07-03, 03:07 PM
JOHN C's Avatar
RE: heater
hi berni.
fitted my heater as far back as possibe and removed the heater control. then fitted the control lever to the right hand side of the driver footwell just below the dash. then attatched a control cable from the lever to the flap on the heater, works perfectly and no tacky plate on the dash.
john c
JOHN
Old 30-07-03, 10:17 PM
RE: heater
An excellent idea, I think.
Thanks, I'll go and fiddle around in the garage!
Old 31-07-03, 07:58 AM
RE: heater
Used Mark Ash's suggestion and put a motor and limit switches in place - push button and it moves the louvre. Removes restriction on location of heater...works well too!
Andy
\"Valui ad satanam in computatrum meum invocandum\"
Old 20-08-03, 09:33 PM
RE: heater
Moved mine back for different dash (own design)
set it to windscreen and put button on dash.
Rgds
Roger
dax heater kitch DAX Technical Questions 2 30-10-06 05:14 PM
Heater Marc General Tech Tips & Questions 20 24-08-06 01:06 PM
Dax heater keane DAX Technical Questions 19 22-01-06 02:10 PM
Heater yes or no ian General Tech Tips & Questions 13 16-04-04 08:54 PM
GD Heater Box. Trigger General Tech Tips & Questions 12 21-02-04 04:33 PM
