Old 04-01-04, 02:49 PM
gareth08's Avatar
Sumo Rad
Hi Guys,
How has anyone fitted the rad to thier sumo,does it come with brackets or did you fabricate your own.I,m using a Transit 4 row rad as I need extra cooling due to the Nos kit
thanks
Gareth
Gareth
Ford 347 T5 w/c
Nothing is impossible there are just degrees of difficulty
Old 05-01-04, 08:40 PM
RE: Sumo Rad
Gareth,
Like you, I did not purchase my rad from Pilgrim (choosing to source one myself and save £40 in the process). It may be that Tony provides the brackets with the rads he supplies. However, the brackets are not difficult to make and only take a small degree of thought and a little muscle. I used a 2" wide, 6" long, strip of mild steel (which was about 2mm thick (excuse me mixing my measures, I am a 60's child brought up in th turmoil of decimilization)). This I bent to so that it would bolt to the top of the upper front cross member and connect, via a Mini exhaust bobbin, to the upper mounting points on the rad. The bottom rad mounting points were attached direct to the lower front cross member (holes already drilled). The bottom mounts take the weight while the upper bobbins provisde an element of anti-vibration. I hope this helps.
Neil
Old 06-01-04, 08:51 AM
RE: Sumo Rad
Gareth,
I fitted my rad in the same way as Neil with one difference.
I have fitted mini exhaust bobbins to the bottom mount so the rad is entirely rubber mounted. The one slight obstacle is that the bobbin is too fat to go into the pre drilled chassis hole due to the adjacent chassis member. I solved this by grinding a flat on the side of the bobbin and it all works finex(
Keith S
Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5
Old 06-01-04, 06:23 PM
gareth08's Avatar
RE: Sumo Rad
Thanks guys
that was along the lines i was thinking of but the mini bobbings are a better idea than what i was going to use.Thanks
Gareth
Gareth
Ford 347 T5 w/c
BB code is On
Sumo MkII v Sumo MKIII bodywork Kimpy21 Pilgrim Sumo Technical Questions 14 31-01-08 09:44 AM
Sumo Tv. nikbj68 General Cobra Discussion 2 28-11-06 07:23 PM
New Sumo Bluesumo Newbies 0 21-12-04 07:48 PM
Sumo MK1 IanM Pilgrim Sumo Technical Questions 2 27-02-04 09:07 AM
302 into mk3 sumo gareth08 General Tech Tips & Questions 3 02-01-03 04:57 PM
