Old 12-11-04, 03:13 PM
Rear Lights
Hi again
Just about to fit the rear light cluster. Standard Pilgrim supply (for now!)
What are the restrictions. Is it indicator, brake, reflector top to bottom as normal or is there more I should know?? e.g. spacing etc
Phil
Old 12-11-04, 05:24 PM
Miket's Avatar
Fully Paid Up Grandad
Re: Rear Lights
Hi Phil
Yes that's correct, indicator, brake, reflector.
Indicator, Minimum separation 400mm, Min height 350mm
Brake, Min separation 400mm, Min height 350mm
Reflectors, min separation 400mm, Min height 250mm
Rear Fog, on centre line or to the offside of car, min height 250mm
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 13-11-04, 10:12 AM
Re: Rear Lights
Mike
Does "separation" mean distance between both side indicators and both side brake lights etc.
Is there any min/max distance between the indicator/brake/reflector within the individual cluster?
Phil
Old 13-11-04, 10:19 AM
Miket's Avatar
Re: Rear Lights
Yes you are correct, shouldn't have put that in to confuse, as its irrelevent really, unless your putting them on the boot lid.
No min/max distance within cluster
AK 427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 13-11-04, 12:07 PM
Re: Rear Lights
Cheers Mike
Top Man!!
Old 13-11-04, 12:18 PM
Re: Rear Lights
Hi again
I've got a fog and a reverse light to fit. The lights are matching and have a swivel mount with one centre fixing bolt. I hope to fix them between the bars of the rear nudge bars equidistant from centre.
The method I hope to use is to cut a piece of stainless flat bar with a centre hole for each lamp mount, then mount each piece of flat bar to the top and bottom nudge bar with stainless U-bolts (with all the nuts facing the car)
Hope this makes sense!!
Do you foresee any SVA probs with this arrangement??
Phil
Old 13-11-04, 05:16 PM
Re: Rear Lights
Should be no problem.
I did a similar arrangement but had the mounts welded to the nudge bar so from the rear of the car you cannot see any mounts at all, just the lights which are a perfect fit between the bars of the nudge bar with the lenses flush to the bar.
Good luck
David
Rear lights russj General Cobra Discussion 5 05-03-06 12:33 AM
Rear Lights NASSTY General Cobra Discussion 18 04-01-06 11:46 AM
Rear Lights Bigblock General Tech Tips & Questions 2 15-09-03 09:31 PM
Rear Fog Lights SimonP General Tech Tips & Questions 17 20-03-03 04:30 PM
Rear lights Shelby General Cobra Discussion 1 28-02-02 06:50 PM
