Front Shocks, Lower Mounting
Gents
I'm at the tail end of my RAM build and have just noticed that my front SPAX shocks are not seated correctly to the lower rubber mount. I know this was not the case when they where originaly fitted, and although I have had the car up and down on the jack , it has not been more than a few Hundred Yards on its wheels. have tried to buy shock mounts with fully bounded steel inserts, but can not get the correct size ( original jags have top mounts designed like this but the internal hole is to small for the lower mounting bolt) is this a common problem ? and can I cure it by adding washers either side of the lower mount to try to add some side load to the rubber mount ? any one solved this problem in another way ( with out buying new shocks)? Regards Steve. |
Re: Front Shocks, Lower Mounting
Not quite sure of the exact problem, here is a picture of mine, any help?
Cheers Myles D-W |
I bought a second hand rolling chassis and changed the spax bushes to poly bushes. I had to use the spax metal inner insert though as the poly one was too long for the lower wishbone gap. It was a doddle. If you were stuck you could easily file or grind the poly supplied insert a little.
Ward sell them as a kit, can't see how anything else could be much stiffer for a light car and you'll have to take yours apart to add the washers anyway. Perhaps yours were never sitting right and forced themselves out? My original ones were one piece so can't see how they could go out of shape without being duf. Sorry but dont understand the problem very well and am beginning to whitter
AKA Ed and not computer literate enough to change \'bitsilly\'. People say to me \'hey you, get out of my garden\'. |
do you mean that the lower bush is not in line with the lower wishbone (i.e. when you look thro the wishbone hole the shock bush hole isn't in line). Means that getting the bolt thro the wishbone and bush is a bit problematic... havin said that they've been like that for 15yrs but are still ok..
http://media.sarawilliams.co.uk :-} |
Gents
Thanks for te info Will look into Poly Bushs. to explain the problem further - the lower metal ring in the shock is nolonger aligned centraly with the lower rubber insert which is bolter to the lower wish bone, ie the rubber sticks out more one side than the other. on Myles's Pic shows the lower bush is silver not black , is this a washer ? Cheers Steve |
Cheers Myles D-W |
Mine uses stepped poly bushes which locates the shock, and solves it.
Regards Steve-serial cobra buyer; is it an illness??? We're not here for a long time, We're here for a good time... |
Russel, could you explain the length of the dampers issue a bit more? Are you saying the Ram advised set up is too high?
Thanks Ed
Does anyone know what the design ride heights for that chassis are?
Cheers Myles D-W |
| steering column lower mounting | Daxman | DAX Technical Questions | 2 | 26-03-07 12:08 AM |
| Front Shocks mounting | cliffords | AK Technical Questions | 2 | 27-02-06 07:08 AM |
| XJS Front Lower Wishbones. | SIMONF | General Tech Tips & Questions | 1 | 02-12-02 05:44 PM |
| Jaguar lower front wishbones | David J | General Tech Tips & Questions | 3 | 01-12-02 09:12 PM |
| AK front lower wishbone fitting | davew | General Tech Tips & Questions | 5 | 07-11-02 08:24 PM |
