Results 1 to 6 of 6
  1. #1
    Steve Faithful is offline Spanner Holder
    Join Date
    Feb 2002
    Location
    coventry, warwickshire, england.
    Posts
    84
    Cheap 3/8in Fuel Filter
    Hi Gents
    I am installing a Carter fuel pump into my Ram and already have a Filter King located near the Carb.
    But thought I should add a Canister type filter between the tank and the pump.
    I have tried to buy one that will locate between the roll bars, ( approx. 55mm dia.) and found that I can either get 5/16in push-on outlets or screw in ( M14x1.5 & M12x 1.5) outlets for about £7.00,
    But no one appears to do a cheap one with 3/8in push-on and I do not appear to be able find any Screw-in adapters, which would enable me to easily connect it to the existing pipes.
    Europa, have a flash machined part for £50.00 which seams to be very excessive for this application.
    Does any one a have any suggestion on how to solve this cheaply ?
  2. #2
    mylesdw is offline Chief Engineer
    Join Date
    Aug 2004
    Location
    Christchurch, NZ
    Age
    52
    Posts
    1,912
    Re: Cheap 3/8in Fuel Filter
    Mr Gasket do a simple cheap inline filter 3/8" press on fittings
    MRG-9748 is the Summit part number, costs $10
    Myles D-W
  3. #3
    Join Date
    Feb 2002
    Location
    Posts
    84
    Quote Originally Posted by mylesdw
    Myles
    Great I will Ring 'Real Steel' and see if they sell them....
    Steve.
  4. #4
    Join Date
    Jan 2005
    Location
    leatherhead,surrey
    Posts
    745
    hi steve
    have you tried your local motor factors there's a huge range of large bodied 'petrol injection' filters (just have an alloy body so take more pressure) or try german & swedish or eurocarparts ? i should think you'd be looking at £5 - £15 depending on how greedy they are on prices......
    NEIL
  5. #5
    Join Date
    Feb 2002
    Location
    Posts
    84
    Hi Neil
    Yes I have tried most of the local trade counters, but can only locate either 5/16in outlets or the screw in ones which I can not get adaptors for ( and can not turn up myself due the odd thread pitch used) therefore need to go further a field?
    Steve
  6. #6
    Purple AK is offline Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    14,967
    Steve. I got a metal bodied one from a local Diesel specialist. It had screw fittings, But they had all the adapters on the shelf.
    AK427 351Cleveland T5WC
  1. Fuel filter
    By kobra in forum Engine Tech Tips & Questions
    Last Post: 28-06-07, 07:51 PM
  2. fuel filter
    Last Post: 24-06-07, 10:49 PM
  3. Fuel Filter
    By Nigel Foster in forum DAX Technical Questions
    Last Post: 13-04-07, 01:43 PM
  4. Fuel filter
    By davep in forum General Tech Tips & Questions
    Last Post: 10-06-06, 06:24 AM
  5. Which fuel filter ?
    By Splitpin in forum General Tech Tips & Questions
    Last Post: 26-08-04, 09:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
