Results 1 to 7 of 7
  1. #1
    Steve Faithful is offline Spanner Holder
    Join Date
    Feb 2002
    Location
    coventry, warwickshire, england.
    Posts
    84
    Speedo 90 degree drive
    Gents
    Doing finishing touches on my kit and wish to install an original mechanical Smiths, 'Cobra' style Speedo but the cable would have to bend too tight to miss the chassis, that is directly opposite the exit from the gear box....
    Therefore any one know where I can buy a 90 degree Speedo cable drive to connect from my 'Saginaw' (GM) Gear box to the smiths Speedo cable.
    Found one in Europa spares for £54 + vat but I would think they are putting a large mark up on this part and just buying it from some one else.
    Any advice?
    Thanks Steve
  2. #2
    Purple AK is online now Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    14,968
    Re: Speedo 90 degree drive
    Speedycables could be your friend http://www.speedycables.co.uk/
    AK427 351Cleveland T5WC
  3. #3
    Join Date
    Feb 2002
    Location
    Posts
    84
    Thanks Chris
    Nothing obvious on the website, I will try ringing them in the week to see if they can help
    Steve
  4. #4
    wilf is offline Banned for owning a STAG!!! Pit Babe Magnet
    Join Date
    Jan 2001
    Location
    On the naughty step
    Posts
    13,783
    Just check which direction of rotation they give - for example, I have a 90 degree drive on my speedo, and it also reverses the rotation, for use with a "backwards reading" instrument.
    Crendon has left the building................bright yellow Stag has landed.
  5. #5
    rickluff is offline Tyre Kicker
    Join Date
    Mar 2005
    Location
    Hailsham, East Sussex
    Posts
    11
    Give Speedograph Richfield a try as well: Email: info@speedographrichfield.com
  6. #6
    Join Date
    Feb 2002
    Location
    Posts
    84
    thanks Richfield appears to have some, will investigate more .....
    I have also been on line to Europa and they are having a 10% sale which helps a little.
    cheers
    Steve
  7. #7
    Join Date
    Feb 2002
    Location
    Posts
    84
    update on my problem.......
    Speedy cable wanted £85 plus and I needed to provide all info .. so if I get any dimensions wrong, my problem.
    Europa said they can only supply one for a Ford gearbox £65
    so I have decided to buy a standar Corvette part (which I have been told will fit any GM box) $44 or £44 from State side autos - my local US parts dealer.. no problems for me.
    I will need to get a cable to to fit but appears to be the best & easiest solution
    cheers
    Steve
  1. Tremec speedo drive
    By Harry-G in forum General Tech Tips & Questions
    Last Post: 21-07-07, 08:17 PM
  2. speedo drive.
    By stevem in forum General Tech Tips & Questions
    Last Post: 19-05-07, 04:33 AM
  3. Speedo drive
    By gareth08 in forum General Tech Tips & Questions
    Last Post: 02-02-05, 07:59 PM
  4. Speedo Drive for a GM T5 gearbox
    By STEVE T in forum General Tech Tips & Questions
    Last Post: 23-04-02, 10:44 PM
  5. tremec speedo drive
    By STOMPER in forum General Tech Tips & Questions
    Last Post: 03-02-02, 11:46 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
