| at least now im almost on the re-build instead of the dismantle thanks for the box i.d. one other question i forgot to mention, not so long ago one of you clever bunch told me how to check diff ratio. I may not have done it right but its an LSD and one wheel hub turned once and the propshaft turn 1.75 times approx. is it that simple i.e. 1:1.75? or is there another calculation?
__________________ --------------------------- Danny L&R Ram 3.9 RV8 - in need of some love |
| That dosen't sound right. If it's a limited slip diff and you turn one wheel the other wheel will also turn at the same speed with it, As if they are on the same shaft. If you turn both wheels one turn then the prop should do either 2.88, 3.01, 3.31 or 3.54 turns Craig.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 16 |
| Cars looking good now. Definitely the right thing to do. I never worked out what the bent wire things were in the brake discs either but I also have them in my Range Rover discs. Wondered if they are some kind of harmonic damper to remove any high frequency vibrations that could cause squealing but just guessing. Craig.
| Quote:
as for the turning of the wheels , i turned the propshaft and one wheel moved, i didnt turn a wheel hub. but i as understand if i turn the prop and both wheels move then its a PL diff ![]()
| The 43/13 tag is the number of teeth on the pinion and the crown wheel. If you divide 43 by 13 you get 3.31 so that is the ratio. That should be fine for a Rover engine. I have a 3.54 in my Chevy powered car and you get great acceleration but a bit less top end speed. If you can turn each wheel independently of each other then it is a standard open type diff or it's a completely knackered power lock one! Craig.
| Quote:
| if ya dont ask you never know! any chance some of you Ram owners would have the loom instructions and maybe the list for the bolt kit? I know its a long shot i just dont fancy having to measure every single bolt before i order some replacements! The loom instructions are purley informational as the loom is existing just needs putting right in a couple of areas.
| Danny, send me an e-mail address and I'll forward my Ram loom instructions.
__________________ AKA Ed and not computer literate enough to change \'bitsilly\'. People say to me \'hey you, get out of my garden\'. |
| Quote:
| Welly boots saga | kobra | General Cobra Discussion | 3 | 11-12-07 11:17 AM |
| The saga of my badly performing RV8 and PILGRIM!! | Sidecarbod | Pilgrim Sumo Technical Questions | 75 | 30-07-07 06:33 AM |
| steam from vents (saga) | kobra | General Cobra Discussion | 10 | 12-02-07 09:22 PM |
| My engine saga - part 5 I want to cry...... | smash | General Cobra Discussion | 27 | 07-05-05 02:45 PM |
| The final saga of my ebay engine..... | smash | General Cobra Discussion | 21 | 24-12-04 03:14 PM |
