Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    l'spa ram driver is offline Spanner Holder
    Join Date
    Mar 2008
    Location
    warks
    Posts
    73
    the interweb has pirellis 235/60/vr15 for £100 EACH corner, similar for 215 60vr15 front (pirelli 600 &6000)
  2. #22
    labeline's Avatar
    labeline is offline Head Mechanic
    Join Date
    Sep 2009
    Location
    Lot et Garonne, France
    Age
    56
    Posts
    851
    Thanks for the response. It looks like mixed Pirelli's are the best choice on a budget. Would have liked the same on all 4 corners
    Cobraless for the first time since 1992......starting to think of another. Crendon or AK....money dependent
  3. #23
    Purple AK is offline Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    15,045
    Quote Originally Posted by labeline View Post
    Mixed Pirellis is the only "budget" choice in V rated I'm afraid.
    AK427 351Cleveland T5WC
  4. #24
    labeline's Avatar
    Join Date
    Sep 2009
    Location
    Age
    56
    Posts
    851
    Don't mind a bit of overkill with a higher rating, just don't want to spend too much of my fast diminishing savings!! I had more or less decided I would get the Pirelli's anyway. Only alternative was bigger rims which is out of the question.
  5. #25
    dgosumo is offline Mechanic
    Join Date
    Mar 2010
    Location
    Hertfordshire
    Posts
    459
    Quote Originally Posted by l'spa ram driver View Post
    What site's listing those for £100 each?
  6. #26
    Join Date
    Sep 2004
    Location
    Nuthall,Nottingham
    Posts
    3
    I changed the tyres on my Ram about two years ago, after spending alot of time looking I finally decided on the following.
    Front Kumho 215/65 R15 96V Solus KH15. these are on 7.5 x 15 rims as specked originally by Ram, I went for 65 ratio as the front ground clearance under the cooler has always been a problem and the front arches looked too big in diameter, these look a lot better.
    Rear Kumho 255/60 R15 102V Ecsta STX. on 9.5 x 15 rims also as specked originally by Ram, both are VR rated and I consider them to be alot better than my old BF Goodritch even when they were new.
    Cost was around 60-80 each.
    Sorry I didn't post about this before but I have only just started reading the Forum
  7. #27
    AlexB74 is offline Chief Bottle Washer and Tea Boy
    Join Date
    Jan 2008
    Location
    Basingstoke
    Posts
    244
    I think the Kumho 255's are too wide for my pilgrims arches unfortunately - a really good option for anyone else though.
    Chap at Blockley tyres only seems interested in making tyres that were OEM sizes on the 60's cobras (I think the sizes they used changed a lot?). And it looks like a long wait till production regardless - he might speed up if they gets lots of enquiries though...
    Just for info Pilgrim factory kitcarman / Den Tanner was very friendly and helpful as always on the phone today - he reckoned the BFG's were perfectly acceptable in his opinion, with a couple of provisos in line with others comments: They wont pass IVA. They will pass MOT and Mr Plod's inspection. Insurance will be fine, but make sure you've told them, in writing. If you are planning serious track work or trips to the autobahns, or, your own 'private road' to max the car out for hours on end, then you need something else (to be fair if thats the route you are going down then a full roll cage, firesuit and helmet might be worthwhile too)
    He also said the sumo (and all other cobras) are so much lighter than the actual weight the tyres were rated to handle there just isn't the pressure on the sidewalls to cause the stress (or the heat) in the tyre. Chaps at North Hants tyres said exactly the same thing (he was selling them though!). North Hants said their BFG stock is no more than 1 year old, 235's are in stock, 215's are expected in early May.
    Alex
  1. 245/55/16" tyre options
    By bobby g in forum General Cobra Discussion
    Last Post: 07-12-10, 08:26 PM
  2. Cheap 18" wheel/tyre package.
    By Stevednorris in forum General Cobra Discussion
    Last Post: 09-11-09, 04:19 PM
  3. 15" tyre sizes
    By cookie1973gym in forum Pilgrim Sumo Technical Questions
    Last Post: 08-06-09, 10:03 PM
  4. Tyre pressures for 17" rims - measure when cold or hot?
    By tigerruss in forum General Cobra Discussion
    Last Post: 21-05-08, 04:39 PM
  5. Wheel / Tyre size for15" wheels
    By donut in forum Pilgrim Sumo Technical Questions
    Last Post: 12-01-08, 03:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
