Results 1 to 10 of 27
    stoke on trent
    373
    Electric or manual choke
    Hi Lads
    What is the usual Edlebrock carb to fit to a 350 the electric or manual choke type, & would a 750CFM work ok with a usual upgrade, preforma heads & inlet.
    Walsall, England.
    424
    Re: Electric or manual choke
    what engine is the carb on, if it was a 351c then 750 would be fine , a 350 chevy with a performer rpm then that would also be ok,
    Adrian
    Hi Tech Cobra (American import) and 393 cu in stroker motor,501bhp 458ft lb
    T Bucket 383 small block supercharged.
    Ford 1934 coupe and 383 stroked Oldsmobile EFI
    stoke on trent
    373
    Cheers Ad
    I am looking to buy a new 750 electric choke unit, & its for a 350 chevy, it should save having a choke cable, is this the norm.
    Nr Biggar
    423
    It matters not which way you go. You barely need the choke anyway. The manual is marginally cheaper and inherently more reliable but you pays your money.............
    194
    Never had trouble starting mine without a choke. It would be interesting to discover just how many are operated with or without chokes fitted/operating.
    Nick
    Jan 2001
    On the naughty step
    13,798
    John - with the accelerator pumps on these carbs, a choke is rarely needed, and the choke's working gubbins only impede airflow when it is not needed.
    I have never been unable to start my engine even in subzero temps, and I stripped all traces of the choke assembly off the carb a long time ago.
    If you really have to , get the manual choke version, then you too can strip it off once you get used to your engine and how it starts in the cold. Or of course, you can leave it on!
    Your choice of course.
    E Sussex, UK.
    2,312
    Mine has a manual but pls dont ask what set up it is with as far as anything els is concerned.
    makes my life a lot easier. I think it would still work without one but it would be an effort.
    Daytona 427..
    Sep 2001
    Walsall, Cultural Centre of the Universe
    71
    1,519
    I have just started running my new carb (Weber 500) with no choke. Starting the engine is fine, it is keeping it running while I reverse out of the drive etc that is the irritation. I was thinking of putting a manual choke on it to prevent the engine cutting out in a potentially dangerous situation.
    David Large
    David Large
    Bald Surfer with a BRA 289
    May 2003
    High Wycombe, Bucks, UK.
    3,419
    John, you don't need either really but as someone has already said it does help when cold to have a method of increasing the idle speed until the engine warms up Osgood
    Jan 2001
    On the naughty step
    13,798
    David - nothing to stop you using a choke cable to activate the fast idle cam without the mixture enrichening parts on the carb.
  1. Fuel Pump - Manual or Electric
    By V8 BJC in forum General Cobra Discussion
    Last Post: 14-02-10, 06:00 PM
  2. feed for electric choke
    By Cobra power in forum General Tech Tips & Questions
    Last Post: 20-12-05, 07:56 PM
  3. Edelbrock Carb 600 cfm - manual or electric?
    By Mr Bling in forum General Tech Tips & Questions
    Last Post: 04-09-05, 07:54 PM
  4. Holley carb+electric choke
    By Kallie in forum General Tech Tips & Questions
    Last Post: 09-02-05, 01:39 PM
  5. Electric Choke carbs.
    By Andy302 in forum General Tech Tips & Questions
    Last Post: 23-04-04, 09:56 AM
