Results 1 to 10 of 20
    What gearbox between a chevy 350/430HP and a jag diff 3.31??
    Can anyone tell me what gearbox will be proper between a Chevy 350/430HP and a Jag diff 3.31?? I'm thinking about Getrag, or Tremec. Any advice on type , where to get it low priced??
    Thanks for the effort!!:thumb: :thumb:
    DrimmanAK:-}
    AK427, it\'s on his wheels and goes to the paintshop in 7 weeks, LT1, T56, :thumb:
    Oct 2003
    Bristol, UK.
    1,958
    Re: What gearbox between a chevy 350/430HP and a jag diff 3.
    As my sig says, i'm running an Edlebrocked SBC 350 to a Jag 3.54PL. I'm running a Tremec 3550 TKO with uprated clutch.
    Whole package including flywheel, clutch friction plate, pressure plate, bellhousing, gearbox, delivery etc came to about 2300 from Brian at Repower/ Roadcraft UK
    Not sure what the final drive ratios are going to be yet, but it was what was recommended.
    Adrian - 350 SBC/RPM, 3550 TKO, 3.54PL, 2005 GD Jag, stopped counting at £28.5k.
    Status: J224 must have developed a fuel leak as my tank appears to be permanantly empty
    Thanks Adrian, that gives me something to work on. altough i'm thinking about a diff with 3.31 or 3.07, this is to give it more acceleration power.
    Rene
    DrimmanAK:-}
    Southwest, Somerset, U.K.
    36
    3,258
    Hi, Im running a 350sbc upgraded to 350BHP and this also is using a Tremec 3550 box. My diff is a 3.54 powerlok. The gearbox was correctly supplied at the same time as the engine from british american engines call Ian Briggs he is a good chap and is always willing to give free advise
    Anthony
    ANTHONY
    Absolute Horsepower Ltd
    Home of the CR427
    Dec 2002
    Eastham, Wirral, UK.
    1,368
    I too am running a 350 SBC RPM performer (supposidly 420BHP) with Tremec 3550 which Bri at Repower said is more than capable of taking that kind of power/torque. probably if you are thinking of doing some track days it maybe worth upgrading to something a little stronger ie. TKO 500/600.
    Cheers, John.
    Drive it like you STOLE it!!
    MJ's Gallery
    Walsall, England.
    424
    i am selling the tko500 at the moment for 1360 inc
    www.americanv8engines.co.uk
    adrian
    Adrian
    Hi Tech Cobra (American import) and 393 cu in stroker motor,501bhp 458ft lb
    T Bucket 383 small block supercharged.
    Ford 1934 coupe and 383 stroked Oldsmobile EFI
    64
    2,264
    If you are running a performer RPM in a 350 forget the 420 HP unless you are up at 7000RPM and have done significant work to the engine you will probably be anywhere between 350 and 375 BHP and if well prepared (zero deck etc etc around 390 BHP (cost me a fortune to get to 395 BHP in my last car with this set up).
    Go for the Tremec that gives the acceleration (in my opinion). The thing I found with the RPM cam was it was geared very much towards acceleration and does little for traffic or touring. As the RPM set up dosent do much for Torque increase, particularly at low end where it hurts, the 500 TKO sounds a good deal should easily cater for the track day set up I would have tought.
    Mike.
    10,035
    I'm running a Tremec TKO 5 speed behind my 383 stroker at 450 bhp (according to the builder).
    I'm also running a 3.07 diff. I find it great for cruising and general blasting but on a track day a 3.54 would be more fun. :thumb:
    Overall 3.31 is absolutely ideal I think you made a good choice there.
    In build- Hawk 289 Sebring
    Nov 2001
    Dubai, UAE
    766
    I'm using a Tremec TKO II 5 speed with a 3.31 in conjunction with a ~350bhp Cleveland.
    No problems from where I stand! :thumb:
    Cheers !!
    David
    10,035
    I can vouch for David's Crendon being a real thrill ride. :thumb::thumb:
    YEEEHAAAH!!
  1. Gearing on Chevy / Jag diff
    By dax dave in forum General Cobra Discussion
    Last Post: 16-06-06, 07:24 AM
  2. gearbox and diff question
    By Speedy Gonzales in forum Newbies
    Last Post: 30-05-06, 06:30 PM
  3. Gearbox and Diff mounting
    By bc_suv in forum Pilgrim Sumo Technical Questions
    Last Post: 01-06-05, 12:22 PM
  4. Gearbox, Diff Questions
    By Warren in forum General Tech Tips & Questions
    Last Post: 04-11-02, 09:00 AM
  5. Chevy, tremec and 3.07 diff?
    By chris m in forum General Tech Tips & Questions
    Last Post: 18-02-02, 08:22 PM
