What sort of bits are you looking for.![]()
I,ve been told of a website which contains the above does anyone know the actual address as I have tried everything.
Mike
Cobraless![]()
I've often been asked, "What do you old folks do now that you're retired? Well, I'm fortunate to have a chemical engineering background, one of the things I enjoy most is turning beer, wine, Scotch and margaritas into urine.
Life's good, live it.
Brake calipers / discs and others apparently!
Mike
Cobraless![]()
Cheers Mike
But none of them it is Ford running gear
Hi
Have a look at this website
http://www.totalkitcar.com/
Loads of usefull links and numbers to companies in there.
Are you looking for Jag of Ford bits?
Craig.
Try this then.Originally Posted by bobdude
http://www.kit-parts.co.uk/
Mike
Cobraless![]()
Mike
Thats the one but not! I am looking to upgrade my brakes which at the moment are standard mk4 cortina thinking of vented discs and new calipers if poss something that would more or less bolt straight on any ideas
You should be able to get those bits from your local Motor Factors.
Probably Cortina GT or Lotus bits.
Mike
Cobraless![]()
A popular mod is princess four pot calipers and bigger discs. Lots of companies do the conversion. Try classic ford mag, lots of places advertise it in there. You could go the willwood or similar route, but would be dearer. Obvious but try e-bay -
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Dax DeDion/351W/RPM/Tremmec & R Performance brakes !
