    Oct 2004
    Calne, Wiltshire
    136
    Nudge Bar Escutcheon Plates
    Hi chaps,
    Can anyone confirm if the nudge bar escutcheon plates that Dax sell (set of 4 for 11) are for the front nudge bars (the oval shaped ones)?
    If so, what diameter of tube are they designed for? If got an Autobrass front nudge bar mounted on 16mm o/d tubing so I'm hoping it's 16mm.
    Alan
    Sumo - 302Windsor - Tremec TR3550
    SVA Passed, Registration here and on the road......yeehaa! Now where\'s the sun?
    May 2002
    Stourbridge, West Midlands.
    347
    Re: Nudge Bar Escutcheon Plates
    Hi Alan,
    I have a set in front of me which i purchased from another member on here which i believe to be from Dax...and the hole , even though is oval measures approx 13mm....but im sure it would not take much to make the hole suit a 16mm tube!!
    ( I also purchased a set of 4 rubber oval 1 piece gromets....which i believe are as per original cob, but i may be wrong.... and look real nice)
    Oct 2004
    Calne, Wiltshire
    136
    Thanks Steve. I've just ordered a set from Dax and will modify to suit if necessary.
    Alan
    stoke on trent
    373
    Hi Alan
    I have also fitted a set of Autobrass nudge bars to the Dax & I'm having a set laser cut for the front & rear, if you have problems send me a mail, I may have a spare set when Ive fitted them.
    Oct 2004
    Calne, Wiltshire
    136
    Cheers John. I'll give you a shout in a few days if the Dax ones don't work.
    Alan
  1. Escutcheon plates supplier
    By bitsilly in forum General Cobra Discussion
    Last Post: 28-09-07, 03:31 PM
  2. SVAable door locks / escutcheon plates
    Last Post: 09-05-07, 08:38 PM
  3. Exhaust Escutcheon Plates
    By Almac in forum General Tech Tips & Questions
    Last Post: 23-11-05, 09:28 PM
  4. Exhaust Escutcheon - where to source?
    By AndrewMarshall in forum General Cobra Discussion
    Last Post: 30-05-05, 03:26 PM
  5. FRont & rear nudge bar escutcheon plates
    By Chimeara in forum Pilgrim Sumo Technical Questions
    Last Post: 16-03-05, 11:23 AM
