Thread: solid fuel line
    Mar 2005
    Manchester
    1,234
    solid fuel line
    I have just finished a genset installation, and i just happen to have 4 metres of 12mm OD stainless pipe, wall thickness 1mm left over!!! are there and problems in using this as the main front to rear fuel line, if it's ok do the ends have to be finished in a certian way to satisfy Mr SVA.
    Russ
    DAX DE DION - CHEVY 383 TWEEKED BY JOHN SLEATH 506 BHP - TREMEC BOX
    10,134
    Re: solid fuel line
    There should be no problem, with that but make sure you have a length of rubber either end to take out the vibration movement, also stainless can go brittle over time so may not last as long as copper.
    Flare the ends as best you can and use two clips on each end.
    STOKE ON TRENT, U.K.
    10,175
    Re: solid fuel line
    There isn't too much trouble so long as you are not running fuel injection pressures through it. if that's the case then you must have proper flared ends or the SVA guy will fail you.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    New Forest. Hampshire
    406
    Re: solid fuel line
    Russ,
    I suggest against lines for 'solid fuel' altogether. Most cob owners tend to use petrol!
    Seriously, The Solid Fuel lines on the fuel injected Jag I broke were stainless, but they did have the flares in the ends to stop the flexis coming off.
    Robin
    AK427
    Jun 2003
    East Sussex, UK
    4,539
    Re: solid fuel line
    I found some seamless hydraulic tubing at a scrap yard which I used to replace the mild steel lines on the BMW... it was a bugger to work with, but it will outlast the car...
    Reverend Robin
    GD427 Euro
    He who dies with the most tools wins
  1. Fuel line Ford 302 EFI
    By Koos.T in forum Gardner Douglas Technical Questions
    Last Post: 11-09-07, 11:24 PM
  2. fuel line issue?
    By TheUnixKid in forum Pilgrim Sumo Technical Questions
    Last Post: 31-08-05, 07:21 PM
  3. Fuel Line Kit ?
    By garyholden in forum General Tech Tips & Questions
    Last Post: 30-06-05, 11:07 AM
  4. Fuel line
    By BIGUNDIES in forum General Cobra Discussion
    Last Post: 03-05-05, 09:28 AM
  5. Fuel line
    By sprocket in forum DAX Technical Questions
    Last Post: 02-02-05, 12:27 AM
