Results 1 to 10 of 13
    Sep 2005
    Salisbury, Wiltshire. UK
    177
    Bargain Mustang 4.6L V8 Cobrajet Engines!
    I have just had a call from John Hearne of JH Imports who I use for importing stuff from the States.
    He has a couple of new Ford Mustang Cobra 4.6 litre V8 Quad Cam engine and gearbox assemblies ready to drop right into something! Here is the spec:
    Ford 4.6L Engine’ Mustang Cobra' '98MY Features are:
    Cast Aluminium 90 degree V Cylinder block
    Cast iron cylinder liners
    Aluminium cylinder head
    Four valves per cylinder
    Dual overhead camshafts, individually chain driven with hydraulic timing chain tensioners on each timing chain
    Roller tipped rockers
    Sequential multi port fuel injection
    Electronic distributorles ignition
    Aluminium intake manifolds
    Basic Technical Details are:
    Power: 310bhp at 5800rpm
    Torque: 300lb/ft at 4800rpm
    Valves: Four per cylinder
    Displacement: 4.6L
    Bore: 90.2mm
    Stroke: 90.0mm
    Compression Ratio: 9.85:1
    Fuel: RON unleaded, 91 minimum octane
    Engine Weight: Dry Basic engine - 240kgs (529lbs)
    with oil and ancillaries - 264kg (583lbs)
    Oil Capacity: 5.7L
    Manual Transmission: Borg Warner T45
    Ratios:
    1st 3.371:1
    2nd 1.993:1
    3rd 1.325:1
    4th 1.000:1
    5th 0.672:1
    Rev 3.221:1
    Full Chassis Drop Specifications includes the following:
    Basic engine assembly (Mustang Cobra)
    Inlet and exhaust manifolds
    Sequential multi-port fuel injection system
    All sensors necessary for Electronic Control Unit input
    Electronic EEC V Power Control Module
    12 Volt starter motor and alternator
    Air conditioning compressor
    Power steering pump
    Drive belts and mounting brackets
    Fuel evaporative loss system
    Exhaust gas re-circulation system
    Engine bay wiring loom
    Vacuum system
    Constant control relay module
    Secondary air pump (exhaust gas dilute) with fittings
    Passive anti-theft (PATS) module
    PATS transceiver and keys
    Air cleaner assy
    Fuel inertia cut out switch
    Exhaust front 'Y' section with quasi catalytic convertors
    Flywheel and clutch
    Clutch actuating mechanisms
    Clutch cable and pedal switch
    Fuel pump resistor and relay
    5 speed Borg Warner T45 transmission
    Rear engine mounting and gearbox support damper
    Gear lever and leather gear change knob
    Power steering supply and return hoses
    Oil cooler
    Fuel filter
    Mustang main wiring loom with distribution box
    Fuel pip and AC pressure hose connectors
    Radiator
    Electric Cooling fan
    Comes with complete Ford Warranty
    Less than £10,000 the lot - give him a ring, he is keen to do a deal!
    Freephone 0800 298 5649 www.jh-imports.com
    Ian
    First Factory Five Racing Cobra in the UK and right hand drive! Ford 351W engine with Edelbrock Performer package = 400 bhp. Tremec TKO 500 gearbox. Car complete, SVA Passed, road legal 6th June 2008!
    http://i74.photobucket.com/albums/i2...m/DSCN3982.jpg
    Jul 2003
    Thirsk, North Yorkshire
    2,121
    Re: Bargain Mustang 4.6L V8 Cobrajet Engines!
    Few points Ian.
    From what I've heard in the past the Cobrajet engines are quite wide and would struggle to fit in a lot Cobra replicas. Something that new is going to need cats to get through SVA. £10k seems a lot of money for an engine and box combo (you could get a 408 stroker windsor doing over 400bhp and tremec box for £7.5k-ish)
    Kev
    Cobraless
    9,511
    As Kev says these engines are very wide and wont fit in most Cobras. Ken had a complete night mare fitting one in which involved modifying the body, chassis, and steering. Bit expensive too so not so much of a bargain
    Jun 2005
    Luton
    482
    I thought the original post said it was for a couple of engines? I know someone who is in process of building a car with one of these - it's in and seems to fit ok.
    It's official! British weather has been declared Muslim.
    It's partly Sunni but mostly Shi'ite.
    Jul 2003
    2,121
    Quote Originally Posted by jemburrett View Post
    Didn't spot that, apologies!
    Kev
    Cobraless
    9,511
    Sorry thought you meant each,
    Worcester Park, Surrey
    3,938
    But Ian..............what COLOUR are they?? :thumb:
    Noel
    Sumo,
    BAE 427ci 560BHP Dart SBC / Edelbrock Thunder 800cfm.
    If all you have is a hammer.....everything starts looking like a nail
    Sep 2005
    177
    Here are some pictures - hope the colour scheme suits!
    Ian
    Feb 2004
    here and there
    4,273
    Hmm multiple valves = more rattles :rotfl:
    Sorry - couldn`t resist.
    There is a fine line between "hobby" and "mental illness."
    You don`t have to be mental to build a kitcar - but it definitely helps.
    GD JAG mk4 finally on the road (but not quite finished)
    Currently got more hp than talent.
    Aug 2011
    East Sussex
    68
    15,858
    Quote Originally Posted by Dutch Paul View Post
    And the prefered choice of engine in GTC
    Chris
    Ex AK427 351Cleveland T5WC
  1. New Carburettor fed LS engines from British American Engines
    By Big Thirsty in forum Snake Watch & Industry News
    Last Post: 05-01-08, 04:29 PM
  2. Mustang - Cobra???
    By 427scr in forum General Cobra Discussion
    Last Post: 28-07-07, 10:27 AM
  3. Mustang Cobra
    By Resik in forum General Tech Tips & Questions
    Last Post: 16-11-06, 08:55 PM
  4. New 2004 Mustang
    By simon in forum General Cobra Discussion
    Last Post: 08-01-03, 07:44 PM
