Results 1 to 2 of 2
    Jan 1999
    Northampton, Northampton, UK.
    9,174
    Holley Vacuum Secondary Tuning
    There are a number of ways to tune the moment when the vacuum secondaries open on a Holley four barrel carb. The vacuum secondaries are controlled by a diaphram and a color coded spring. Holley makes a number of different springs with different tension on the springs. You can change the springs and change the opening moment. The color coded springs run from light tension to heavy:
    White - Lightest
    Yellow (Short Spring)
    Yellow
    Purple
    Plain (Steel grey)
    Brown
    Black - Heaviest
    If there is a bog or hesitation when the secondaries open, the spring tension is too light, go to the next heavier spring. Holley offers a kit (PN-20-13) which contains one each of the above color springs. When you change springs you'll note that the stock cover over the spring and diaphram is not all that easy to get to. Holley makes a special cover (PN-20-59) that makes spring changes quick. Finally, Holley also makes a completely adjustable thumbscrew operated diaphram cover (PN-20-99). This cover limits the travel of the diaphram and therefore limits how far the secondary throttle plate can open. It makes secondary throttle opening adjustable. It's very nice to have if you are a bracket racer and are using a carb with vacuum secondaries. You can adjust the throttle for changes in weather and track conditions or for changes in your "dial in".
    Best Regards
    Robert
    West Yorkshire, England.
    1,748
    Re: Holley Vacuum Secondary Tuning
    Quote Originally Posted by robert
    White - Lightest
    Yellow
    Purple
    Plain (Steel grey)
    Brown
    Black - Heaviest
    Some more good info on tuning Holleys found here
    http://www.bob2000.com/carb.htm
    Lee
    Understeer is hitting the wall with the front of your car, oversteer is hitting the wall with the rear.
  1. Holly Secondary Vac spring change
    By MetaJacko in forum General Tech Tips & Questions
    Last Post: 07-07-05, 01:12 PM
  2. Anyone use a Vacuum ? (ooh err!)
    By PeteV in forum General Cobra Discussion
    Last Post: 04-04-05, 10:13 PM
  3. Holley Tuning
    By Mike in forum General Cobra Discussion
    Last Post: 18-09-03, 11:18 PM
  4. Holley 600 Vacuum advance query
    By nbracken in forum General Tech Tips & Questions
    Last Post: 13-08-02, 09:51 PM
  5. Holley Tuning Info
    By Mike in forum General Tech Tips & Questions
    Last Post: 17-02-02, 05:36 PM
