Results 1 to 4 of 4
    Jun 2003
    SPA-Francorchamps, Belgium.
    14
    Who drives a KF Premier?
    Hi to all from Spa,
    I purchased a fully built KF Premier in 2003. I only know it's the forerunner of the AK427 and as I could see in the build manual of the AK several elements look indeed very similar.
    There is no roll hoop fitted on my car and I wish to fit one. I took a look at the chassis and saw that no mounting plate is fitted on the top of the rear brace (like on the AK's) to fix the rollhoop brackets.
    I asked AK and they told me that the very early chassis did not have the mounting plate for the roll hoops.
    The boot would have to be cut out and the plate fitted to take the roll-bar tubes.
    Is there a solution to fit rollhoops on this chassis without removing or cutting out the body? How are they fitted on You KF Premier?
    Best regards
    Felix
    Jun 2003
    14
    No KF Premier owners?
    So, no KF Premier owners in GB or Europe?
    I know they were build in the early 90's.
    Felix
    Chesterfield, Derbyshire
    51
    2,134
    Hi Felix, Don't be dismayed by the lack of answers as only a few KF's were made, and if anyone knows them its Ken so you may well have the best advice already.
    Having said that, it may be worth checking with Ken to see if its possible to put the plate on top of the GRP in the boot, and bolt through to the chassis, as the roll bars are not structural this may be viable.
    Just a thought,
    You know it makes sense
    rich.
    All Things Cobra.Com
    the cobra builders resource
    Jun 2003
    14
    Hi Rich!
    Thank You for Your advice! I will check trough the "inspection hole" in the rear wall of the cockpit if the distance between the GRP in the boot and the chassis is not too important.
  1. Anyone with a Premier Wiring loom????
    By kevchard in forum General Tech Tips & Questions
    Last Post: 01-08-07, 10:40 AM
  2. Premier wiring; Relays?
    By jon milner in forum General Tech Tips & Questions
    Last Post: 04-08-06, 09:24 AM
  3. She drives!!
    By Robin427 in forum General Cobra Discussion
    Last Post: 07-07-05, 05:32 PM
  4. What the hell's a "KF Premier"?
    By smash in forum General Cobra Discussion
    Last Post: 29-05-05, 06:25 PM
  5. Premier wiring loom
    By jeff in forum Pilgrim Sumo Technical Questions
    Last Post: 27-05-04, 01:30 PM
