Results 1 to 3 of 3
    Jan 1999
    Northampton, Northampton, UK.
    9,180
    Upgrade Imminent
    Ok, I have tried to break the new forum, without success, so I will be upgrading the forum at some time this evening, so it will be unavailable.
    Points to note below.
    1. The user profile now uses different fields as this was necessary to include preferences. Pre-6.2 profiles will not work...essentially, every registered users in your forum must re-do their profile. Also, advise your users to carefully look over the preferences as they will be set to the default values.
    2. The way signature is handled has changed. The signature is now dynamically added when the message is create: that is, the signature is not written to the message database. You will find that this has many benifits, for example, hot having to deal with signatures when you reply to a message that uses a signaure. Please goto User Menu > Edit your profile and save it once to initialize it.
    Now, the side effect of this new signature method is that the older posts with your signatures will have duplicate signature. Hopefully, those topics will eventually "fade" away...
    2. The MARK time stamp will require re-initialization...that is, hit MARK ALL once. The older time values will not work because I implemented a more accurate time stamp function.
    Best Regards
    Robert
    The temporary NON-Whistler!
    Best Regards
    Robert
    imported_admin Guest
    RE: Upgrade Imminent
    Robert
    Silly boy here again,Question?
    1, What is signature?
    2, What is MARK TIME?
    Steve G.
    Jan 1999
    9,180
    >Robert
    Its the bit at the end of the post, best regards etc etc
    You have two options, time stamped, or marked. one is automatic, the other is manual.
    >Steve G.
    Robert
    The Whistler!
    Best Regards
    Robert
  1. Upgrade
    By robert in forum General Cobra Discussion
    Last Post: 03-10-05, 10:54 AM
  2. Tom Tom 5 Upgrade
    By Happy Jim in forum Feedback, Membership and Help
    Last Post: 27-06-05, 05:04 PM
  3. HELP!!! hari-kari imminent!!
    By crendonman in forum General Tech Tips & Questions
    Last Post: 18-08-03, 08:39 AM
  4. Upgrade
    Last Post: 17-04-03, 09:38 PM
  5. v6-v8 upgrade
    By andybearne in forum General Cobra Discussion
    Last Post: 12-06-02, 08:02 PM
