    Palm Beach, Florida
    467
    Switch GD steering wheel
    Has anyone with a GD switched to a wooden steering wheel. I don't care for the RAID wheel and the way the steering column protrudes through the dash. I think I will change out the steering column and steering wheel. Anyone done any of this and have pictures or advice?
    GD Euro #51, brought from damp and rainy Tipperary to Florida
    May 2003
    Bridgnorth, Shropshire.
    2,989
    on the Mark 4 body, GD use a vectra column and switchgear, which uses the original switchgear instead of all the switches on the dash.....not original, but infinitely easier to use than a dash switch setup
    YOu of sourse can add a wooden wheel to the boss for either mark 3 or mark 4, with the appropriate steering boss.
    I think you can just replace the raid wheel and steering boss for a motalita wheel
    DAX 383 ci SBC 440hp...SOLD
    GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
    Project Tango "Old School" GD, 440 hp LS3 ....SOLD
    460 HP LS Griff "a gentlemens cobra"....SOLD
    630 HP LS7 TVR Tamora
    Palm Beach, Florida
    467
    Thanks Steve. I have the MK III with the Jag column. I will talk to Andy to see what options I have.
    I really don't like the column itself and after seeing some other Cobras at Sebring this past weekend would like something cleaner.
    Quote Originally Posted by pcoghlan View Post
    I have a wooden steering wheel on my GD. I do not have pictures to hand, but I hope the following might be helpful. I have a steering column from a Jaguar XJ6 as recommended by GD. The wooden steering wheel is a Motolita wheel (Cobra Style), dished and the dished wheel allows me to have indicator arms, which I have adapted from a Vauxhall Astra (was not keen on the switches on the dash board) The dished steering wheel also enables me to have twist switches behind the steering wheel for the lights and heater. The steering wheel is 14", I believe it is larger than the average Raid which Andy has on the GD, which I think is 13". I went for a 14" as it looked better (only my preference). However, the issue with the 14" is as follows, the distance between the steering wheel and the door is very small, especially if you also have a cockpit surround. To get over this I also purchase from Motolita a 1" spacer. This was OK for me with the wheel out slightly further than normal and moved the steering column over to the left as far as possible. This movement to the left does not make a signficant difference it was the spacer between the dished wheel and the column that generated plenty of room (With the steering wheel closer than with the Raid you may find this uncomfortable, however I have no problem with the distance, it appears to me to be more comfortable, I'm about 6ft tall) Hope this helps
    Cheers OE
    Aug 2005
    East Grinstead
    162
    Couldn't remember whether you were a Mk.3 or 4. The Vectra column used on the Mk.4 is finished better I think (and has the better instruments). I didn't go with the GD wheel and also didn't fancy a wooden wheel so went with something else which was a bit smaller to give a bit more leg/arm room
    Mk. 4 GD / SBC383 Performer RPM / TKO600 / Big grin...
  1. Big Nut Behind the Steering Wheel
    By Lloyd Barnes in forum General Tech Tips & Questions
    Last Post: 04-11-08, 10:34 AM
  2. Horn switch position and steering lock query
    By Superarnie Mk2 in forum General Cobra Discussion
    Last Post: 28-12-07, 09:20 PM
  3. Steering wheel
    By cwdm in forum Pilgrim Sumo Technical Questions
    Last Post: 02-06-07, 10:28 PM
  4. SVA Steering wheel?
    By Wheelnutter in forum AK Technical Questions
    Last Post: 30-09-04, 07:09 PM
  5. Jag Steering Lock & Switch & Key
    By Happy Jim in forum General Tech Tips & Questions
    Last Post: 16-04-02, 04:42 PM
