Results 1 to 3 of 3
    Jan 2008
    Basingstoke
    1,118
    Side screens/wings - quick release?
    Hi Chaps,
    I've currently got some old sidescreens (metal frame job) fitted. They dont fit properly in line with the hood, the plastic has gone hazy due to spilling petrol on them and they are just a bit knackered all round. So I'm after a few suggestions...
    I had an plan to cut really long/deep (Lexan?) wind wings with a bit of rubber along the bottom edge (without a frame) and use them as side screens instead. The existing wind wing hinges, air pressure and the hood itself I think should make a reasonable fit.
    The only downside I can see is running without the hood on they will look a bit daft. However if i could work out some way of having them fixed to the hinges with a quick release clip I could swap them out for the normal ones easily.
    Any thoughts or even better suggestions on a quick release clip/bolt?
    Alex
    Pilgrim Sumo MK2
    Jan 2009
    blackpool lancs.
    5,092
    Alex, these have been covered many times before, and some very good ideas, from our very inventive chaps, try the search function, you should find just what you want, Regards Col
    Jan 2008
    Basingstoke
    1,118
    Ah! just done a search - that'll teach me look first!
  1. quick release steering wheel boss
    By bw41059 in forum General Tech Tips & Questions
    Last Post: 07-10-09, 07:39 PM
  2. Dax Quick Release Harness - Is it SVA Approved?
    By bogster in forum General Tech Tips & Questions
    Last Post: 12-12-06, 08:52 PM
  3. Quick Release Steering Wheel
    By Goldie in forum General Cobra Discussion
    Last Post: 16-06-05, 09:55 PM
  4. Quick Release steering wheel mechanism
    By Tobias in forum DAX Technical Questions
    Last Post: 26-02-04, 09:26 PM
  5. Quick release -Snap off steering wheel
    By kdavies3 in forum General Cobra Discussion
    Last Post: 02-10-03, 11:09 AM
