Results 1 to 9 of 9
    opington kent
    39
    edelbrook Calibration
    was woundering if there is anyone out they that could help me Calibrate my carb i am willing to drive to them i just get my head round it.
    pilgrim sumo mklll chevy 350bhp+tremec500 supplied by british american engines.
    opington kent
    39
    Quote Originally Posted by jason barnes View Post
    sorry what i was ment to say i have the chart just cant understand it
    Jan 2009
    blackpool lancs.
    5,093
    Yes i have the same problem, must have read through the book three times an i still dont "get it"
    8,046
    I can help you with the chart but in my humble its useless anyway! it has errors in it and jet/rod combinations are missing! (At least from the 500 chart)
    What carb are you running? (If its the 600 then the factory jetted it as two different versions, one being an emission control jobbie).
    I have a spreadsheet that works much better than the charts, you bung in the standard settings in the top row then bung in any jet and rod combo that you like. The spreadsheet then compares the new combination to the standard setup and gives you a percentage leaner for cruise and the powerstep. (Some bloke on the forum wrote it for me as I was doing it all by hand with a calculator)
    You can have a copy of the spreadsheet if you PM me an email address.
    (Tell me what the carb is and I'll bung in the base settings for you)
    There is a VERY good book on ebay that tells explains how these carbs work.
    I wrote my own version before I read the book, its here:-
    How To Build a Pilgrim Sumo: Fueling System
    The gumph on the wiki is aimed at RV8 lumps but its still worth a scan read. (How the jets and rods work is explained).
    Pete
    Jan 2009
    blackpool lancs.
    5,093
    This is the only book i need
    8,046
    Jan 2003
    9,482
    Jason, would it not be best to consult BAE before you could make things worse??
    David
    SR full rebuild, now on the road, needs trim to finish
    TWM EFI 388ci 550hp/520tq
    Power steering fitted.
    8,046
    Quote Originally Posted by Clarkson View Post
    BAE deliver engines with the carb set out of the box, much like most other engine suppliers.
    Noel's engine 383 (supplied by BAE) ran about 8 percent too rich in cruise mode, as far as I can remember the acceleration mode and WOT were not far off the mark.
    I have already emailed Jason and explained that to set the WOT properly the exhaust gas will need analysing however it is perfectly possible to set up the cruise just by driving the car. If you go too lean you won't damage the engine as it is virtually under no load. It is very easy to tell if its gone to lean in cruise as the engine will hunt like crazy and/or be as flat as a fart.
    Apr 2008
    Farnham
    65
    1,823
    Pete
    BAE SBC 350 (with a Carb...)/ TKO500 / 3.54PL -
    Less of a mess now but still plenty to do...
    Number of polishes - 1/2 and a bit...
    SOLD...SOLD...
    If I'd known I was going to be so thirsty this morning I'd have drunk more beer last night.
  1. Transducer Calibration
    By Black Hawk in forum General Tech Tips & Questions
    Last Post: 12-05-09, 09:19 AM
  2. Speedometer Calibration
    By chris98m in forum Pilgrim Sumo Technical Questions
    Last Post: 24-04-09, 08:15 AM
  3. SPEEDO CALIBRATION
    By Ian Harrison in forum General Tech Tips & Questions
    Last Post: 05-03-04, 05:00 PM
  4. Speedo Calibration
    By griff in forum General Cobra Discussion
    Last Post: 05-01-04, 11:31 PM
  5. Speedo Calibration
    By RigMan in forum General Tech Tips & Questions
    Last Post: 23-06-01, 03:24 PM
