Results 1 to 2 of 2
Thread: steering rack
    Apr 2009
    Aquitaine - France
    steering rack
    hello my sumo MK2 all work is finished I will be present at the gathering in ST TROPEZ 7.8.9 in May, I still have two issues key to the wheels (front wings winner) when turning the steering wheel to the right or left, there there a stubborn set in motion?? and my second question, for better braking est'il possible to mount brake ford scorpio (which are broken down) in lieu of Granada are simple, I am sorry but I use a translator to write j ' hopes that it remains understandable
    serge
    8,045
    Check that the wheels are not catching on the bodywork as they are turned. they can foul at the rear of the wheel arch.
    If they are OK jack both wheels off the ground the knock the track rod end ball joints out from the uprights but leave them connected to the track rods so that the wheels are no longer connected to the steering rack, then turn the steering wheel to feel to the tight spot. You should then be able to work out what the problem is.
    No sure about the brakes but anything is possible with enough determination!
    I refuse to engage in a battle of wits with an unarmed opponent.
    Rules for buying 'Go Faster' parts:-
    If it's fast and cheap then it's not good.
    If it's cheap and good then it's not fast.
    If it's good and fast then it's not cheap!
  1. Mk4 Steering rack
    By daveymuso in forum Gardner Douglas Technical Questions
    Last Post: 11-05-09, 08:49 PM
  2. Steering Rack
    By pete goodwin in forum Newbies
    Last Post: 02-03-09, 04:49 PM
  3. Steering Rack
    By lee427 in forum DAX Technical Questions
    Last Post: 10-01-06, 01:08 PM
  4. Steering rack set up
    By richardd in forum General Tech Tips & Questions
    Last Post: 16-05-04, 08:17 PM
  5. Steering Rack
    By BAZ in forum General Tech Tips & Questions
    Last Post: 10-03-03, 10:13 AM
