    Apr 2006
    Milton Keynes
    144
    Charging problem
    Ive had a problem where I was overcharging and boiling the battery. I put this down to faulty voltage regulator in the alternator as the output was reading 16.2 volts.
    Ive fitted a new alternator and battery but am still reading 15.8 volts at 2,000revs.
    What can be causing this?
    RAM 427 SC
    Chevy 350 tuned engine & T5wc box
    400BHP
    Jan 2001
    On the naughty step
    13,798
    Is this a one wire or a three wire alternator?
    The issue could be the voltage sensing wire - where does it go?
    As you say, 15.8V will cook the battery.
    Crendon has left the building................bright yellow Stag has landed.
    Apr 2006
    Milton Keynes
    144
    It has 3 wires. Please see pic attached.
    Could the 2 top wires be wrong way round?
    RAM 427 SC
    400BHP
    Jan 2001
    On the naughty step
    13,798
    It is possible, but I couldn't say for certain.
    Might just be worth swapping to see what happens.
    Does your "charging" light work as normal?
    Apr 2006
    Milton Keynes
    144
    Thanks Wilf.
    Swapped the wires round and issue now resolved.
    Ive now also got a spare working alternator.
    RAM 427 SC
    400BHP
Similar Threads
  1. alternator charging?
    By Kimpy21 in forum Pilgrim Sumo Technical Questions
    Last Post: 05-11-08, 11:12 PM
  2. Charging problem.
    By srv8dave in forum General Tech Tips & Questions
    Last Post: 04-09-08, 03:52 PM
  3. Charging problems
    By ianhunter in forum Engine Tech Tips & Questions
    Last Post: 11-05-08, 08:08 PM
  4. ROAD CHARGING!
    By wilf in forum The Cockpit
    Last Post: 24-05-07, 10:05 AM
  5. Is my battery charging?
    By saviller in forum General Cobra Discussion
    Last Post: 01-09-05, 09:40 PM
