Results 1 to 7 of 7
Thread: IVA Seatbelts
    2,260
    IVA Seatbelts
    do all the nuts on my seatbelt system need to be welded to the chassis for the IVA test ? I know the four nuts that are fitted to shell are bonded in, but what about the two by your hips ?
    Craig
    Jun 2008
    long eaton nottm
    73
    262
    Mine just have load spreader plates fitted under the body, with nylok nuts and bolts,I have a wilians 4 point harness fitted, passed IVA ok.
    2,260
    Thanks Tony, are your spreader plates welded to the car of just sandwiched with the bolts?
    Sep 2004
    Bressingham
    1,331
    They do not need to be welded just of the correct grade and attached through an area that will be strong enough in the inspectors opinion. Unless you can supply evidence of compliance.
    2,260
    thanks for the answers, that's saved me another job. IVA early in Jan hopefully.
    Sep 2004
    Castle Donington
    228
    The spreader plates need to be fitted so that if you undo the seat belt bolt they do not fall off the car. On mine I fitted a small retaining bolt in one corner of the spreader plate this satisfied the SVA tester I assume it should for IVA test.
    Ian
    chippenham ,wilts
    162
    HI , Im a long way off from this but its rattling around in my head , how difficult is it to fit harnesses into a sumo for the IVA ? is it possible , as i dont understand why pilgrim dont give you the option .
  1. seatbelts
    By stevem in forum General Cobra Discussion
    Last Post: 27-09-07, 08:19 PM
  2. SVA seatbelts/harnesses
    By bitsilly in forum General Cobra Discussion
    Last Post: 30-01-06, 01:23 PM
  3. sva question ( seatbelts )
    By andywatkiss in forum General Cobra Discussion
    Last Post: 21-07-05, 11:20 PM
  4. Fasten your seatbelts
    By Louise in forum The Cockpit
    Last Post: 27-01-05, 03:58 PM
  5. SVA and Pilgrim Seatbelts
    By glencoe in forum Pilgrim Sumo Technical Questions
    Last Post: 02-10-04, 08:46 AM
