One dont put new lifters on different heads with different pushrods as I know you have without setting preloads you are aking for trouble. Make tool from apiece of coat hanger wire bend one end at 90 degrees for about 12mm and the other end the opposite way. File one end until it measure 60 thou the other to 20 thou. . With the rockers and push rods installed Valley out set each pot to tdc at firing stroke. With the too try each end into the gap between the circlip and the follower. If the twenty doesnot fit the gaps to small if the 60 fits its to big the 60 should fit but be very tight.If they dont fit you have to find out the largest and smallest and select shims to go under the rocker posts. The whole thing is not exact and involves quite alot og compromise. RPI have a page on their web site that explains it. Good luck. Otherwise ring RPI and ask for Holly he will talk you through it.
