Results 1 to 3 of 3
Thread: Oil Cooler
    Stourbridge, West midlands.
    25
    Oil Cooler
    I have been offered a Mocal racing oil cooler, 19 row 1/2 b.s.p.
    does anyone know if this would be o.k. to use? (have ford 302 engine)
    cheers.
    steve
    Jan 2001
    On the naughty step
    13,798
    RE: Oil Cooler
    Steve - original fit on 427's was, I believe a mocal 16 row, 235mm wide item. In any case, this is what I used on my 408 stroker windsor, which had considerable oil temp problems before I fitted it, and now seems OK. The only comment I have about your proposed unit is the size of the ports - we ought to aim for 3/4" bore pipework (JIC dash 12)and corresponding fittings, but if it's cheap - go for it. A new 16 row/235mm wide cooler with bigger fittings is only around 60. Main cost is in pipes and fittings etc. Remember to include an oil thermostat in your system - engines don't like overcooled oil.
    PS see my post in the consumer watch section re sandwich take-off plates.
    Wilf
    25
    RE: Oil Cooler
    Many thanks for the advice wilf
    regards
    steve
  1. Oil cooler
    By bogster in forum DAX Technical Questions
    Last Post: 10-04-06, 03:40 PM
  2. Oil Cooler Take Off
    By SJ in forum DAX Technical Questions
    Last Post: 30-01-05, 11:45 PM
  3. HO 502 oil cooler
    By Dezino in forum General Tech Tips & Questions
    Last Post: 29-01-05, 07:43 PM
  4. Oil cooler
    By chesterak in forum General Tech Tips & Questions
    Last Post: 22-03-04, 10:43 PM
  5. Oil Cooler
    By mjculley in forum General Cobra Discussion
    Last Post: 25-06-03, 10:40 AM
