Results 1 to 8 of 8
    Stourbridge, West midlands.
    25
    Battery location
    where is the best position for the battery?
    Engine bay------too hot!!
    passenger footwell-------space restriction
    boot space----petrol tank/rear end shunt!!!!!!
    would appreciate general view
    cheers
    steve
    imported_admin Guest
    RE: Battery location
    In my dax i put it over the back axel
    Jan 2001
    On the naughty step
    13,798
    Steve - put mine in the passenger side boot well. Best place to counter torque reaction on take off (rear n/s wheel tries to lift??). Anyone hits you in the rear hard enough to make that a problem - your necks broke anyway! (don't you just love the lighter side of life?)
    Only thing is you have to use real thick cableon the run up to the front to eliminate volt drop.
    my 2cs
    Wilf
    Put it behind the passenger seat, like the original S/C's and comp cars.
    I Have a Dax the battrey is up front , and as its fitted with a Rover engine that is light, the battery compensates with a little extra weight, one other advantage is the ease you can get at it, also you can attatche an inspection light with no problems, it does not get hot either.
    WORCESTER, UK.
    67
    Normally RAM batery is fitted in the boot over either arch
    Rob
    Southend On Sea, UK.
    292
    Over rear axel. Passenger side if you can.
    RigMan.
    WORCESTER, UK.
    67
    Fair play Rigman thats where mine is going in my RAM
    Rob
  1. Speedo location
    By steamyrotter in forum Viper Tech Forum
    Last Post: 29-10-07, 10:18 PM
  2. Dipstick Location
    By Martyn-ak427 in forum AK Technical Questions
    Last Post: 08-02-07, 10:54 PM
  3. Location for Battery Isolator
    By chedz in forum General Tech Tips & Questions
    Last Post: 20-04-06, 11:12 PM
  4. Header tank location
    By demus in forum DAX Technical Questions
    Last Post: 12-12-04, 05:37 PM
  5. A question about sidepipe location.....
    By johnnycobra in forum General Tech Tips & Questions
    Last Post: 21-03-04, 03:10 PM
