Results 1 to 10 of 16
Thread: Tremec Oil??
    Jan 2001
    On the naughty step
    13,798
    Tremec Oil??
    Just finished putting my jag diff back together to cure output shaft oil leak. Not a job I want to do again!
    However - whilst under the car for so long, I noticed the the gearbox is also gettin' kinda' leaky. Have a tremec TKO, using the Dexron II fluid as recommended. Have small oil leak from shifter area, also I think I can see the signs of some leakage now through the front input shaft seal. Nothing from the rear seal as yet - thats drizabone.
    Have seen some posts before about tremecs leaking using the standard oil, so does anyone have a tried and tested alternative? And did it stop the box leaking?
    WIlf
    Prestwick, Ayrshire.
    273
    RE: Tremec Oil??
    My Tremec leaks also. It did when it was new. It has just been stripped down and rebuilt(not because it leaked) and it still leaks but in a different place. It also has a small leak at he input shaft area. I use Dexron 11 also.
    Alex
    Crendon no 52
    Ford 351C
    Jan 2001
    On the naughty step
    13,798
    RE: Tremec Oil??
    Alex - my sympathy - ever heard of anyone using a redline transmission oil instead of the DexronII? That's what I want to find out about - the Dexron fluid is so d**m runny it's bound to leak! What did the supplier of your'box say?
    Wilf
    Greensboro, North Carolina, USA.
    14
    RE: Tremec Oil??
    Wilf-
    My understanding is that the Tremec manufacturer advises that nothing but GM Synchromesh transmission fluid should be used in the Tremec 3550 and TKO 5 speed trans. I've heard some people report good results with Redline hi-dollar trans oil in the Tremec, while others have reported that the GM product works best- that Redline gives a "notchy" feel to the shifting [whatever that is]. I went to my local GM dealer to get some Synchromesh fluid for my Tremec and was told that the original part number GM Synchromesh fluid I had requested had been discontinued and replaced with another. This new stuff had a generic-looking label like "GM Manual Transmission Lubricant" or some such. I hope he sold me the proper stuff. I haven't driven the car yet. I have heard of auto trans fluids like Dextron mentioned above being used in the T-5 transmission, however.
    I have heard good things about Forte's parts as a source of Tremec parts and info http://www.fortesparts.com/ . I believe that Tremec's website is www.ttcautomotive.com/welcome.htm . There may be some authoritative info sources linked there somewhere.
    Dan
    Dan
    Jan 2001
    On the naughty step
    13,798
    RE: Tremec Oil??
    Dan - thanks for your help. Looks as tho' tremec's do resmeble sieves on average, decided not to worry about the few drips I get for the time being. Perhaps after I 've ruined my clutch a Wroughton I might attend to it??
    Wilf
    Southend On Sea, UK.
    292
    RE: Tremec Oil??
    Getting oil out of the shifter sounds a bit extreme...did you overfill it Wilf? Now that you have a tight rear end, I wouldn't like to thin you had a messy front! *chuckle*
    RigMan
    Jan 1999
    Northampton, Northampton, UK.
    9,180
    RE: Tremec Oil??
    The mind boggles. I certainly wouldn't ask to have a look at Wilfs rear-end, however tight it might be.
    >RigMan
    Robert
    The Whistler!
    Best Regards
    Robert
    Rushden, Northamptonshire, UK.
    101
    RE: Tremec Oil??
    Prunes should help!
    Jan 2001
    On the naughty step
    13,798
    RE: Tremec Oil??
    Glad you are all so interested in my rear end, since that's mostly what you'll see of my car on Saturday!!
    Yours in Fords
    Wilf
    Jan 2001
    On the naughty step
    13,798
    RE: Tremec Oil??
    Good point Rigman, but no I didn't overfill it. Have now established that Tremecs can leak from the most surprising of places! My rear end is fine thank you, also dry!
    Wilf
  1. Tremec
    By kobra in forum General Tech Tips & Questions
    Last Post: 25-11-07, 11:18 PM
  2. tremec tko 600
    By petecob in forum General Cobra Discussion
    Last Post: 24-09-04, 10:04 PM
  3. Tremec TKO
    By salmon in forum General Tech Tips & Questions
    Last Post: 21-09-04, 02:55 PM
  4. tremec oil
    By craigh in forum General Tech Tips & Questions
    Last Post: 01-08-04, 09:39 PM
  5. tremec TKO and RV8
    By snake_bitten in forum Engine Tech Tips & Questions
    Last Post: 30-03-04, 10:17 AM
