Thread: Oil Pressure
    Milton Keynes, UK.
    137
    Oil Pressure
    Help.
    I have a new 350 [Repower] all is running well apart from the oil pressure.
    Guage goes off the scale and the led remains illuminated.
    The sensor is earthed OK.
    All else is wired to the instructions [Pilgrim] ETB instruments.
    Any ideas please???
    Thanks Guys
    www.munderhill.co.uk
    summers commin....
    Jan 2001
    On the naughty step
    13,798
    RE: Oil Pressure
    Martin - don't know your particular brand of instruments, but I assume you have an electrical rather than mechanical oil pressure guage.
    If so, you must have a problem in the wiring somewhere, or a faulty sender. Do you have any donor bits to temporarily check with?
    Is the sender matched (in terms of resistance ) to the gauge? Is it a proper sender at all, because it sounds as tho' you might have an oil pressure light switch instead of a sender?? This might give the results you see now.
    HTH
    WIlf
    Mike Guest
    RE: Oil Pressure
    If electrical then the instrument can be checked by earthing it through a resistor. This should be done twice, once at the top of the scale and once at the bottom. If you do not know the resistance range then your manafacturer or Speedy Cables should be able to tell you (Number else where on this site). This is best done with a simple circuit away from the car, that way you eliminate any wiring problems. If the instrument reads OK then it can only be:
    a) the sender b) the wiring. Lets presume its not the engine.
    RE: Oil Pressure
    you may have the same problem I had with my fuel sender, the resistance range on the sender went the wrong way for the gauge (though both were smiths parts), the US and European standards are (surprise, surprise!!) completely different, one goes from 10 - 180 ohms , the other goes from 240 to 30 ohms (can't remeber which one is which), this may explain why your sender goes off the end of the scale when/if you have no pressure. Measure the resistance across the sender with the engine off and check with the spec for your gauge to work out if this is the case, in the case of the oil pressure sender this probably won't be too much of a problem as you can swap it for the right one (unlike my petrol level one!!)
    stuart
    Milton Keynes, UK.
    137
    RE: Oil Pressure
    Thanks Wilf,
    It is electrical and both Sender and guage is supplied by ETB, as is the wiring diagram.
    I'll contact them as it looks more and more like a faulty sender.
    martin
    summers commin....
    Milton Keynes, UK.
    137
    RE: Oil Pressure
    Thanks to all who replied.
    I have now sorted the problem.
    It was a poor wire in the loom [run a new one and is OK]
    summers commin....
  1. Oil Pressure
    By chiffer in forum General Tech Tips & Questions
    Last Post: 08-11-05, 02:11 PM
  2. Oil Pressure
    By rick turner in forum General Cobra Discussion
    Last Post: 20-09-05, 11:18 PM
  3. Oil pressure Take-off
    By Goldie in forum General Tech Tips & Questions
    Last Post: 07-05-05, 09:25 AM
  4. Oil Pressure
    By marc davis in forum Newbies
    Last Post: 02-05-05, 10:37 PM
  5. Oil Pressure
    By ss083 in forum General Tech Tips & Questions
    Last Post: 23-09-02, 03:40 PM
