Results 1 to 10 of 13
Thread: Castor
    Southend On Sea, UK.
    292
    Castor
    Having sorted out my camber and tracking, I have turned my attention to Castor. On my Jaguar front suspension I have the 'straight' upper wishbone arms (as opose to the 'cranked' type). Does any one know whether removing the castor shims which are meant to be located to the REAR of the upper ball joint (front on the cranked type) aid/improve the front wheel self centering ability or not?
    All answers greatfully received!
    RigMan.
    STOKE ON TRENT, U.K.
    10,174
    RE: Castor
    do you have lower wishbones that have the ball joint socket cranked at an angle?
    if yes it should be cranked forward.
    the top wishbone is a little weired their are two types that i know of, first the most common type has a kink in both arms near to the the bushes these are found on the same cars as the above described lower wishbones and each arm is the same length and shape the only diference is the hole where the jag bumpstop rubber is screwed in ie.both on the bottom side. if you have this set up all three castor shims should be to the front of the car.
    however if you have the same lower wishbone but have the other type upper wishbone (whishbone arms do not have a kink near to the bushes and are of unequal length with shorter leg at the rear) the three shims all fit to the rear of the car . for any other combination ,like a straight lower wishbone
    and an ofset upper wishbone as described above in ( ) i would assume that the shims go to the front but if youre not sure give peter or gary at dax a call.
    Good luck.
    DAVE PRO.DAX BUILDER
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    292
    RE: Castor
    I have the second of the two scenarios that you described above where the shims locate to the rear of the upper ball joint. The question remains; do I remove the shims to improve wheel centering/positive camber or add them? Also, when adjusting castor, does this upset the front tracking?
    RigMan
    10,174
    RE: Castor
    to give stronger self centering remove shims from the rear and put them in the front, best tried one at a time.
    because the wishbones are angled to the rear on a dax as you move the shims to the front this will alter the camber of the car slightly to the negative (top in). and there is a very good chance that this will also affect toe in/out but these effects could be so slight that they fall within original tollerences.
    are you experiencing a serious handling problem or is this just fine tuning?
    Good Luck
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Shanghai, China
    1,139
    RE: Castor
    Dave, I have the upper arms with the crank in them. The self centering on my car is fine but the steering does get really pretty heavy as I put on more lock. If I move shims from the front to the rear progressively will this reduce self centering but also lighten up the steering weight? The steering weight only becomes a problem beyond about the 50 pct mark.
    Nigel B
    Unique Autocraft Python
    Chevy 350 ZZ4 TR3550
    Ex UK, Germany, Japan, UK and now back in Germany once again!!
    1972 Ford Mustang Mach 1 Cobra Jet
    351 Cleveland with 4 speed hurst shifter
    USA
    10,174
    RE: Castor
    IT SHOULD DO. BUT DO TREAD CAREFULLY , DO THEM ONE AT A TIME AFTER ALL YOU DON'T WANT TO TAKE A SHARP LEFT TURN AND BEFORE YOU KNOW IT END UP ON THE FOOTPATH.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    292
    RE: Castor
    Thanks for your responses Dave. I am basically fine tuning, but being a little critical have found that the steering under speed is not exactly 'reasuring'. I have removed one shim each from the rear of the ball joint but did not replace it to the front rather I just left it out.Is this a problem? I no longer seem to have to drag the steering back to centre any more as I exit a corner, but the steering seems to be a bit nervous on a 'straight'. This would suggest camber, but I have alreaddy set that up to within 0.5 degrees of spec.
    Thanks,
    RigMan
    Jan 1999
    Northampton, Northampton, UK.
    9,180
    RE: Castor
    Don't forget that if you put much castor change on, you will affect the bump steer, so you might want to chack this after the castor change.
    Just a thought.
    Robert
    Forum Admin
    http://www.cobraclub.com/flags/UK.gif
    Best Regards
    Robert
    10,174
    RE: Castor
    RIGMAN , YOU MUST PUT THE SHIM BACK IN, THE ARMS ARE DESIGNED TO HAVE THREE SHIMS IN THERE EITHER AT ONE SIDE OR THE OTHER, WITH A SHIM REMOVED THE ARMS WILL NOT BOLT UP TRUE PUTTING EXCESSIVE LOADS ON THE TOP WISHBONE BUSHES ALSO THE BOLTS THAT RETAIN THE TOP BALL JOINT WILL PROTRUDE TOO FAR AND YOU RUN THE RISK OF THE THREAD HITTING THE DISC WHEN YOU OPERATE THE STEERING.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    10,174
    RE: Castor
    RIGMAN HAVE YOU SORTED IT YET?
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
  1. Castor Angle
    By MarkyC in forum DAX Technical Questions
    Last Post: 16-07-07, 10:54 AM
  2. Castor Confirmation
    By BenBaron in forum General Tech Tips & Questions
    Last Post: 03-11-06, 09:53 PM
  3. castor measurement
    By rileyhr in forum Pilgrim Sumo Technical Questions
    Last Post: 25-04-06, 05:50 PM
  4. How to measure castor ?
    By Martijn Vink in forum DAX Technical Questions
    Last Post: 25-10-05, 05:54 PM
  5. castor
    By David J in forum General Tech Tips & Questions
    Last Post: 11-03-04, 06:15 PM
