    Nov 2001
    Melksham, Wiltshire, UK.
    31
    Rover V8 Crack pulley bolt - help!!!
    I've spent hours trying to get the b*****d bolt off but couldn't. Tried heating, WD40, big hammer, sledge hammer and praying but nothin has worked. PLS HELP!!!!!!
    Chris}>
    Leigh on sea.
    224
    RE: Rover V8 Crack pulley bolt - help!!!
    I take you have used a plate to bolt the flywheel to the block so that it wont move. That bolt is done up to 217 Nm and takes alot of cracking as you well know.The slightest movement will stop it freeing up.It could be worh investing in a new socket and the shortest possible extension and then a long tube to increase the leverage. Good luck
    Dax, Ford 351W.
    124
    RE: Rover V8 Crank pulley bolt - help!!!
    I had big problems with this one also. Solution? A 4ft lever. Make sure the the block is on firm ground and held in place so it doesn't rock about, then keep pushing on the lever with quite a bit of force, lots of short blasts rather than one enormous effort. It should soom come free.
    Jim.
    Nov 2001
    31
    It came off
    The problem was it was on a trailor (not in a car). In the end mr 8 foot torque wrench helped us. Thanx for the advice people...
    Chris}>
    Re: Rover V8 Crack pulley bolt - help!!!
    ARGOS, 12volt electric impact wronch, its for undoing wheel nuts but the bect bit of kit I have bought in years, will undo the most stuborn pully bolts , engine in or out of car!
    Sep 2004
    Redditch, Worcs
    52
    795
    I would suggest if you a impact socket that fits and the engine is in a trailer pop down to your local tyre fittment place and for the cost of a drink i am sure they will undo it for you.:thumb:
    Iain
    Living the dream on a daily basis
  1. tightening the Crankshaft Pulley Bolt.
    By martin_t in forum Engine Tech Tips & Questions
    Last Post: 21-08-07, 08:18 PM
  2. Cant undo Crankshaft Pulley retaining bolt
    Last Post: 20-04-06, 08:49 PM
  3. crankshaft pulley bolt slackening
    By Kassi in forum Engine Tech Tips & Questions
    Last Post: 29-03-05, 05:40 PM
  4. lucas alt rover v8 pulley???
    By MARTIN123 in forum General Tech Tips & Questions
    Last Post: 03-08-03, 10:41 PM
  5. Rover V8 Bolt ratings
    By Dan in forum Engine Tech Tips & Questions
    Last Post: 21-02-03, 09:13 AM
