Results 1 to 10 of 21
Thread: SVA Fail
    Milton Keynes, UK.
    137
    SVA Fail
    The tester had a quality inspector in toe so I had no chance..
    I need to prove age for my Chevy 350 block no 10066036 the list provided by Mortec has no year for that!! Pilgrim tell me that loads have gone thru OK on this documentation..
    I've e mailed Mortec so I hope to resolve that.
    The tester needs to know the Maximum Engine speed,
    any ideas? Can't be road speed as it would be effected by gearing.
    Could it be RPM?
    The rest of the list is made up of minor bits so I'm not that cheesed off.
    www.munderhill.co.uk
    summers commin....
    Chipping Campden.
    79
    RE: SVA Fail
    Hi Martin
    Very sorry to hear about your SVA fail. My commiserations.
    I have a list of casting block numbers from 1955 up to about 1984. I can see no mention of block numbers starting 100. My list courtesy of the book "Small block Chevy" lists block numbers from 30... to 39... and 14... and 46... etc. If you would like a copy, email me and I will scan the page and send it down the tube. From what you have said I guess it must be a later block.
    You don't say where you had it tested but I assume from your location it must be Leighton Buzzard?
    Cheers John
    Wellingborough, Northants, UK.
    275
    RE: SVA Fail
    Hi Martin,
    Sorry to hear about your SVA Nightmare (just wot you dont need an inspector) also,
    I'm sure it'll go thru next time.
    I've also looked thru my lists for sbc's and cannot find any block markings starting with 100....
    This may sound silly but you are reading the number from just above the Bellhousing near the dizzy on the passenger side?
    Just a thought
    NuttyNorm
    STOKE ON TRENT, U.K.
    10,167
    RE: SVA Fail
    Hi Martin.
    Where did you get your engine from...was it a used one from a breakers,an imported one,or a brand new one as the casting number seems to indicate.
    The engine speed issue that you refer to is actually the maximum power engine speed,carefull on this one though as you might have problems getting under 101db,cos that is what they're after.If you tell them that your engine produces maximum power at 4000rpm they will test the noise level at 3/4 of this = 3000rpm and should help you through the noise.
    If you can't resolve the engine age problem (no proof)you are going to have to find an old "shagger" Chevy engine to put in your car just for the test and then swap the main engine back in afterwards....A pain in the ass i know but it could be the only solution.
    Good luck.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    Sep 2001
    DENBIGH, DENBIGHSHIRE, UK.
    171
    RE: SVA Fail
    well i got a problem as well, the bloke who did my engine forgot to make a note of the number and when the block was machined , off came the number , but I do have a set of number punches !! perhaps some one could give me a number before 1984. i am told that they changed the side of the oil dip stick on later engines but can't remember from when to where .
    Regards Steve T
    Leigh on sea.
    224
    RE: SVA Fail
    What a bummer and after all that work its enough to make you want to cry (well I would have) Dont let it get you down there are are enough experts out there to help you with this engine number problem. On the list I have compiled from various web sites your actual number does not show up.It doesnt mean its not there its justI havent found it; but from what I have 10054727 is 86 upwards and 10066038 is a 1994. This may point you in the right direction. But I think it must be down to Tony to come up with an official letter of some sort to help you out after all he sold you the bloody engine in the first place,dont take its never happened before as an answer there is always a first time and this is it.
    whats the little face for seriously pissed off.
    Leigh on sea.
    224
    RE: SVA Fail
    On the list I got from the web 14010201 14010202 14010203 14010207 and 14010209 are all listed as numbers for years 80 -85 for a 350 chevy.
    10,167
    RE: SVA Fail
    Hi Steve.
    Do you mean to say that he machined off the casting number?
    The casting number is situated on the top rear left corner of the block,right behind the cylinder head ,in efect on the top of the "gable end" that the bell housing bolts to.This is not an area that is machined during any rebuild.The engine number may be gone but the casting number should still be there.
    checkout http://www.mortec.com and do a search around...if your engine ain,t new it should be there.
    The SVA use the information from Mortec as their guide as to the age of an engine,I know this because when the SVA was first introduced i contacted the SVA at Swansea with regard to a Chevy engine that i had and they told me that if it hadn't come from a UK registered vehicle I would have to get a letter from Chevrolet stating the date of manufacture of the engine,I explained that this could be almost impossible and that there was a website that listed the Chevy casting numbers and would this be sufficient evidence?They told me to print it off and post it to them.A couple of days later i got a phone call from them saying that it would be fine and could they keep the paperwork that i had sent.They also told me that if i had any problems with this info at the SVA test that i was to tell the inspector to call HQ in Swansea and they would confirm that all was ok.
    This information at Swansea can prove very helpful if you have a genuine old engine....but if you are trying to cheat the system you could get some problems.
    I also spoke to Swansea about using a new block with recon parts in it,telling them that it was an old style block and that newer style engine parts would not fit.In effect trying to get a new Goodwrench through...no good they wouldn't buy that one, but worth a try i thought.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Milton Keynes, UK.
    137
    RE: SVA Fail
    Hi John,
    Thanks for the offer, I have the same book.
    I'm pretty sure I'll get the solution from Mortec or the engine builder.
    Yep it was Leighton Buzzard.
    The station would still get a 5 star rating in the SVA review, it was just my bad luck that the Inspector Called!!
    summers commin....
    Milton Keynes, UK.
    137
    RE: SVA Fail
    It was purchased via Pilgrim from Repower, so if I can't get a quick solution I'll pass it to them.
    You are right about the power issue, they were testing the max sound at 4K RPM, and I know it should be at 3K!
    I'll get the proof and go again.
    If it needs an engine swap I'll #####;'@ shoot someone @ Pilgrim.
    Thanks for the support.
    summers commin....
  1. sva fail
    By KevinW in forum Pilgrim Sumo Technical Questions
    Last Post: 12-10-07, 10:01 PM
  2. SVA Fail Points
    By cheepskate in forum General Tech Tips & Questions
    Last Post: 02-10-04, 07:27 AM
  3. SVA Fail Points
    By Ranger Bob in forum Pilgrim Sumo Technical Questions
    Last Post: 20-04-04, 06:18 PM
  4. MOT fail sorted, SVA next
    By beanpole in forum Pilgrim Sumo Technical Questions
    Last Post: 22-02-04, 09:33 AM
  5. SVA Fail #2
    By Martin427 in forum General Tech Tips & Questions
    Last Post: 17-03-02, 08:16 PM
