Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Oct 2010
    united kingdom
    71
    Hi dobbo put me down for 2 with the third legs pending price for the de dion
  2. #22
    Buckshaw Village
    542
    Quote Originally Posted by p1stol View Post
    Is this with or without the bolt through??
  3. #23
    Jul 2009
    Carmel and Nantwich
    242
    Hi Steve,
    Would like 2 of them but I would need 3mm wall thickness if they can do it, as I need to weld on harness points? Could you confirm the OD of them aswell?
    Aside from that I'm happy with 2 or 3 leg and could go mild steel as I'll likely be coating them black anyway, all depends on the final price.
    Adam
    1985 RAM Cobra
    3.9 RV8 plus other non-ram bits
  4. #24
    Buckshaw Village
    542
    Quote Originally Posted by Adam001 View Post
    Hi Steve,
    Adam
    Adam,
    At present am looking to do the 1.5mm hoops but will look at getting a price for the 3mm as a single hoop in mirror and mild steel for you. I am looking to put together somthing for the 3 legged versions but as with everything it takes time to actually work out the total cost correctly.
  5. #25
    1,376
    Hi Steve, give me a price for the 3mm in stainless roll bar bent on a 12" centre please. Also can you supply a 1.5 metre length of the stainless 3mm tube, I wil make my own slip joint and weld it to were I need on the roll bar. Ta Lee
  6. #26
    Oct 2010
    united kingdom
    71
    Hi Steve put me down for 2 in the 3 mm tube for the dedion and I'll take 2 of the lengths 1.5 m and weld my own legs on
  7. #27
    Buckshaw Village
    542
    Just an update on the 3mm stainless pipe, the guys I buy it off don't normally stock this item and as it would be a one off order they are going to put a large delivery charge onto the cost which would make these far too expensive it would be cheaper to buy them direct from DAX. Sorry guys but if you want 1.5mm tube then can accomodate.
  8. #28
    Apr 2009
    Portsmouth,UK
    50
    297
    Steve,
    I am interested in 2 for my Dax De Dion with the third leg to bolt through to the harness mounting. Do you these replicate the Dax units exactly in height etc ?
    Can you also pls confirm that the £50ea price is for the mirror stainless ?
    Adrian
    Dax De Dion 239 in its new garage - Wasn't ready for 2013 but what about 2014 ?MMM missed that. Lets try for 2015 !
  9. #29
    Buckshaw Village
    542
    Quote Originally Posted by adriant View Post
    Steve,
    Adrian
    Adrian,
    The price of £50 is for the single hoop in mirror finish stainless but has marks from the bending process so would need to be polished further. Am in the process of negotiating a better price to polish them with the guys that do all our stainless work and should have a price shortly.
    The three legged version, is being designed off the DAX Dedeon chassis I am building at the moment so will fit any DAX chassis as long as DAX have made them all the same (can't guarantee others workmanship). I should have a complete costing for the hoops in the next couple of weeks so will post on here as soon as I know.
  10. #30
    Jan 2010
    hucknall
    hi can you tell me the od of these as i want to check that they will fit mine
  1. Replies: 5
    Last Post: 15-05-11, 05:46 PM
  2. Roll Hoops
    By TBP Engineering in forum AK Technical Questions
    Last Post: 23-11-09, 01:08 PM
  3. Roll Hoops
    By Churchill Pete in forum DAX Technical Questions
    Last Post: 21-10-08, 07:05 PM
  4. Polished stainless roll hoops made to order
    By simon in forum General Cobra Discussion
    Last Post: 10-10-02, 08:35 PM
