Results 1 to 10 of 19
    9,655
    Dip tube sender for an AK
    Due to the fact that the fuel gauge is so inaccurate on 99% (Purple AK being the exception ) of AK we have found a tube sender which could answer all the problems, Merlin are selling a 166mm VDO for £71-84p, and we might be able to get a bit off this if we get a group purchase together. There will be a bit of work required as the fixing is 5 hole and not the 6 hole that AK use but this is not really a big issue plus you might have to make up a small circuit so that it will match the gauge but someone on here will be able to design something to solve this. If you are interested just let us know and we will sort out something to suit all. I guess if other people want ones of a different length this will help so feel free to ask.
    SIEMENS VDO - VDO DIP TYPE FUEL SENDER 166.0 - 224082008018
    Aug 2011
    East Sussex
    69
    15,858
    I'VE never run out of fuel though Martin Stoneleigh 2009 was it?
    Chris
    Ex AK427 351Cleveland T5WC
    9,655
    Quote Originally Posted by Purple AK View Post
    Sorry Chris no idea what your on about
    Apr 2012
    Wrexham
    584
    Hello,
    I have already ordered a 190mm one, and will make up a spacer flange (i think my tank is a little deeper than norm....)
    Interested in the circuit though....
    Gav
    Mar 2005
    westmidlands
    5
    dip tubes go up and down the same as normal floats and so will your guage
    i know i had one some also only read by 1/4 tanks so suddenly drop quater tank at time
    best to move sender to center of tank inside triangular internal baffle then sponge fill outer section
    May 2002
    Leicestershire, UK.
    1,492
    I think Tinks still holds the record for the lowest mpg ever recorded -or not recorded in his case
    Richard (-the one with 2 mad Wheaten Terriers)
    Ex-GD 325bhp RV8 builder/owner
    9,655
    Quote Originally Posted by sid1 View Post
    If you had one that did then there was something wrong with it as they don't at all. The idea of a tube sender is they have a small hole at the top and one at the bottom so that petrol can only get in and out slowly to stop this problem .
    9,655
    Quote Originally Posted by maxGD059 View Post
    Thanks Richard
    Jun 2009
    wiltshire
    255
    Unhappy VDO Dip Pipe Sender
    Thanks Richard
    Hi Martin,
    Lots of comments about the capability of Dip Sender. but not much interest in our Group buy,
    Only 1 degree in my garage so work has come to a stop.
    Sitting indoors with lots of tea and biscuits!!!!!
    Alan
    9,655
    Yes looks like a waste of time sorry to delay you, might as well go ahead and order yours. Won't be doing mine till next year when I swap my diff for a different ratio.
