Results 1 to 10 of 10
    Oct 2010
    Kintbury Berkshire
    34
    Iva Engine question
    hi guys
    just getting ready for the iva but i need an engine number.
    i have put a ford small block in the car with a 1965 block which i can prove from the block casting number but i dont have an engine number as such.
    can i just just make one up to identify it from this point on, or does it have to match a data base of something
    hope some one can help
    regards Andy
    Shropshire
    1,247
    Hi Andy,
    Making up engine numbers isn't a good way forward.
    Casting numbers and stamped numbers are on the block why would you use anything else?
    You will need someone to verify the age owing to silly sods flogging blocks with false numbers. I don't know who the current verifying people are but someone will be along to advise.
    Good luck
    Stu
    Oct 2010
    Kintbury Berkshire
    34
    Hi Stu
    where on the block is there a number stamped i have found the casting numbers but i cant find an identification number as such.
    thanks Andy
    Perth
    4,640
    The casting number, which you say you have found, is on the block behind the starter motor and shows the age of the block. The actual engine number wasn't stamped on the engine, but was on a metal tang which was attached by a bolt to the engine. This often becomes detached and lost over the years especially if the engine is worked on or rebuilt. A quick search show how to decode the casting number to show the year of casting. Small Block V8 (5.0): Casting number id and general info links - Updated 6-10-06 - Ford Truck Enthusiasts Forums
    Cheers, Clive
    Jul 2004
    UK
    8,107
    There probably wont be a stamped number if the block has been decked/refaced, but there should be a casting number.
    Ford engine blocks are usually aged from the engine casting number, so for example a 1965 small block will be C (1960 decade) 5 (for the year) then model designation from A (full size) to Z (Mustang) etc etc then it would have an E for 'engineering', so C5AE is a common block casting number.
    I understand that this is what the engine dating guys will look for, and not a stamped engine number.
    My understanding is that the blocks the IVA people are most wary of is small block Chevrolets because of the number of mexican blocks that were presented as earlier blocks; but everything needs dating now.
    David Clarkson was talking of getting approved to age engines for IVA purposes and he's not that far from you; drop him a pm 'clarkson' on here to see if he can do that?
    Regards Steve
    Crendon #22
    452cu FE with top loader
    10,066
    I'm not sure you need an actual engine number for IVA?
    But you will need an official age confirmation from an approved source.
    I used Peter Knight at Knight Racing Services.
    I sent him pictures of the casting number and the engine in the car.
    Not cheap but you need it.
    In build- Hawk 289 Sebring
    Sep 2011
    woking. surrey
    39
    Hi
    i had my 289 engine date proofed by real steel. and they made up an engine number and stamped it to the block. to identify it was one they had looked at and for iva purposesi dont think were representative of anything else
    10,066
    I had an engine number on mine too but it wasn't a Ford one, probably been put on during a rebuild over it's 50 years.
    Mine was two letters and 4 numbers.
    i.e. XY1234.
    It's stamped on the front of the block just below the front of the head deck face.
    Peter Knight referenced it on his paperwork too.
    Oct 2010
    Kintbury Berkshire
    34
    thanks Guys
    you have all been a great help i will get on the case
    regards Andy
    Aug 2006
    Winchester
    40
    301
    Not sure about IVA bur I didn't have an engine number when I SVA'd mine. It is just blank on the v5
    Dax de dion. 383 Stroker and EPAS for the wife. SVA PASSED. Bring on the summer!
