Results 1 to 3 of 3
    2,934
    Radiator removal
    Hi all in SRV8 land
    Have a bit of a leak that looks to be coming from the bottom of the radiator somewere (not pinpointed as yet). My question is, is it possible to remove the radiator without removing the engine?
    Jan 2009
    blackpool lancs.
    5,092
    Hi Gary, Had mine in and out a few times due to leaks, thankfully its very easy, I can just undo the support bracket, and it drops straight down, if your is on a removable bracket/s you may be able to do the same, jack up the front of the car and have look or take a pic and post, BTW I just have a can of bars leaks now in the system and it hasn't sprung a leak for ages: Halfords | Bars Leak Radiator Sealer 135ml
    2,934
    Well, i know this is an old post, but in answer to my own question - then the answer is yes, yes you can remove the rad without removing engine
    the rad will come out in two ways - either drop out from the bottom if you remove the rad cradle first, and will also come out through the bonnet area if you remove the top rad pipe and rad expansion tank to.
    You need to tip rad back towards engine area and rotate it clockwise whilst wiggling it a bit, but there is plenty of space to do so.
    regards
