Results 1 to 8 of 8
    Apr 2009
    plymouth
    306
    Sierra column switches
    'Evening all,
    On top of the R/H Sierra column switch cluster there are two spade connectors. can anyone tell me what they are for? The Pilgrim wiring diags don't seem to refer to them and they don't appear to be numbered. Am I right in thinking they should be connected to earth?
    Regards,
    Andy.
    Building Granada based Mk3 Sumo With 3.9 RV8
    1,368
    Hi andy,
    Yes they are earth connections for the horn.
    Rob
    Apr 2009
    plymouth
    306
    Quote Originally Posted by robcob View Post
    Hi andy,
    is
    Rob
    Hmmm...Rob, I don't think they're for the horn, as I have a centre push in the middle of the steering wheel which is connected via a black two-pin connector to earth and the neg side of horn relay.(All wired in and working)
    Andy.
    Oct 2005
    1,885
    Ignore the connectors, the switch should earth through the screws that hold it on with an earth wire. at least mine works that way!
    Sumo, modified
    Jan 2009
    Hampshire
    306
    When I did mine if you didn't earth to these the lights didn't work properly.
    Les
    Newcastle upon Tyne
    1,917
    Quote Originally Posted by tigergreen View Post
    . . . . . Am I right in thinking they should be connected to earth?
    Andy,
    As Rob said they are both Earth connections but not, as you have said, for the horn. Attached gives Sierra pin outs & Pilgrim connections. You will need 31 connected, 55 is earthed when the side lights are on – not needed for standard Pilgrim loom.
    Hope this helps,
    Ian
    Apr 2009
    plymouth
    306
    Thanks for replies, chaps and to Ian for his excellent comprehensive diagram.
    I just nipped out to the garage and using a multimeter, did notice that when the light stalk was operated, a connection was made internally between the two spade connectors.
    So, as they're both for earths, then, as Ian says, there is only need to connect the one marked '31' to earth (a little job for the morning.)
    Regards,
    Andy.
    Chadderton, Nr. Manchester
    1,902
    Yes, thanks for that diagram
    Oh crap...the wife has realised there is no such thing as a 5 minute job !
